Registered members do not see this advertisement! Remove it by signing up for free.
genesis motors forum   genesis motors forums
Direct Links: Genesis Motors Brand | Genesis G70 | Genesis G80 | Genesis G90 | Genesis Sedan | Genesis Coupe | Equus
Genesis Forum: 5.0 L V8 Oil/Filter Change 2015
Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 41
  1. #31
    homeofstone is offline Registered Member What I drive: Genesis 4.6 V8 Tau Sedan
    I live in Athens, Georgia, USA
    Join Date
    Oct 2010
    Age
    64
    Posts
    3,263
    Cars in my garage
    Rep Power
    10
    Default Re: 5.0 L V8 Oil/Filter Change 2015
    Members don't see this ad
    Quote Originally Posted by Genentec View Post
    just changed oil filter on my 5.0 at dealer. 26 bux can't beat it.
    conventional oil I'm guessing.
    Current vehicles:
    2011 4.6 with tech, Athens, GA owner
    2011 Mercedes E63 AMG
    2005 Mercedes E500 w/sport pkg.
    2013 GMC Yukon XL Denali AWD
    1965 Ford Mustang 289cid V8 restored
  2. #32
    Lord Humunculous's Avatar
    Lord Humunculous is offline Supporting Member What I drive: 2G Genesis 3.8 V6 Sedan
    I live in Texas
    Join Date
    Oct 2015
    Posts
    140
    Cars in my garage
    Rep Power
    2
  3. #33
    Join Date
    Sep 2013
    Posts
    534
    Cars in my garage
    Rep Power
    4
    It cost me $50 to do it myself, but over $40 of the total was the 8.5 quarts of Mobil 1. I would cut my oil change interval to about 4000 miles if I didn't use full synthetic. I am not sure which would be less expensive, but I am more comfortable with the full synthetic and longer interval. In addition, the 7500 mile interval is less hassle.
    2015 5.0 Ultimate, Casablanca White with Black Interior Build Date July 2014
    Options:
    Mud guards, trunk mat, rear bumper applique, wheel locks
    Customization:Automatic turn on of heated/cooled seats, Automatic raising/lowering of rear sunshade
    Other Vehicles:
    2008 Toyota Sequoia Platinum
    2005 Lincoln LS V8
  4. #34
    Join Date
    Sep 2013
    Posts
    534
    Cars in my garage
    Rep Power
    4
    By the way, I am probably one of the few people who put oil in the filter prior to screwing it on. I fill it about half way (all the way and then it seeps down). I have done this for years to reduce oil starvation.
    I actually had an electric pump in a car years ago that would build the oil pressure prior to starting the car. The house from the pump replaced the drain plug. The pump was also used in oil changes to pump the oil out. I could use it in the Genesis strictly to pump the oil out for an oil change. There is really not enough room for the pump under the hood and modern oils are much better with cold lubrication. In addition, my car is garage kept in TX, so cold starts are less of an issue. I probably will not do this because of warranty questions and the hassle of installation will take many oil changes to make up the time.
  5. #35
    Join Date
    Sep 2013
    Posts
    534
    Cars in my garage
    Rep Power
    4
    I am using 0w-30 Mobil 1 because I like the high temp performance better than 0w-20, especially in TX. I am glad that the owner's manual says 0w-30 is allowed in the 5.0 engine.
    I had another vehicle which I noticed slight valve tapping on 0w-20 (it was the preferred oil) and this went away when I used 0w-30.
    The synthetic oil definitely flows much better than conventional oil.
  6. #36
    Genentec is offline Registered Member What I drive: Genesis 3.8 V6 Sedan
    Join Date
    Dec 2012
    Age
    41
    Posts
    340
    Cars in my garage
    Rep Power
    5
    Default
    Im sure the oems know what oil is best for their Genesis.
  7. #37
    Mark_888 is online now Registered Member What I drive: 1G Genesis 3.8 V6 Sedan
    Join Date
    Jan 2009
    Posts
    10,910
    Cars in my garage
    Rep Power
    19
    The auto manufacturer knows which oil viscosity is needed to get the maximum fuel mileage for EPA testing to met CAFE (Corporate Average Fuel Economy) targets that they are required to meet. That does not necessarily mean the recommended oil viscosity is best for engine longevity.
  8. #38
    kn5owa is offline Supporting Member What I drive: 2G Genesis 5.0 V8
    Join Date
    Feb 2015
    Posts
    1,096
    Cars in my garage
    Rep Power
    4
    Mobil 1 was originally advertised and marketed in the mid-70's - when it was first introduced - as providing 5% better mileage than conventional oil. We had gas lines in the 70's for those that remember.
    Mobil 1 easily pays for itself, if even a good fraction of that 5% rule still applies.
    Drives '06 Sonata LX V6
    2015 Genesis 5.0 V8
    Montecito Blue
  9. #39
    azgolfrat is offline Hasn't posted much yet... What I drive: 2G Genesis Sedan
    Join Date
    Nov 2016
    Age
    57
    Posts
    7
    Cars in my garage
    Rep Power
    Quote Originally Posted by kn5owa View Post
    Everyone who has done the oil/filter change on the 2015 Genny V8 (including dealers) seems to agree that it is a first rate bear to remove the under panels that prevent ready access to the filter assembly and drain plug.
    The long rear panel that covers the pan drain plug is particular hard to remove/replace.
    My question is: Has anyone tried used something like the MityVac oil extractor to remove the oil on this engine? Then only the front panel has to be removed.
    My thinking is the engine has a "cable" type dipstick and a convoluted dip tube to match, so the idea ain't so good.
    Any ideas/experience?
    I've done two oil changes so far, using a manual pump Mityvac. I've been able to get about 7.5 liters out with the pump and then catch another half liter when the filter comes off...so I think there is a liter to a half liter being left in the pan. I'm ok with that. On my 1st change I took off the front panel to access the filter. It wasn't too bad getting off and it was a bit more difficult to get back on, but again, quite doable. Probably 10 minutes to get off and 20 minutes to get back on. Maybe a bit less than that. I did not have to jack up the front end (not sure if I could in a way that would be helpful) to get to the filter, as it is pretty close to the front underside. There is no getting to that filter from above (2015 v8 5.0). I have discovered it is important not to over pump the mityvac as it causes something like cavitation, getting air bubbles in the exit tubing, which slows down or stops the oil evacuation. If you have a manual mityvac like mine, pump slowly until you get a good solid (and it will be slow, but no bubbles) exit stream, and then let it go....seems like 10-15 minutes to empty the pan. Please let me know if you have questions.
  10. #40
    Join Date
    Jan 2009
    Posts
    10,910
    Cars in my garage
    Rep Power
    19
    Quote Originally Posted by azgolfrat View Post
    Long ago, I starting trying to extract oil with a couple of different manual pump extractor units, but gave up in frustration. However, the Mityvac 7300 works great, but requires an air compressor which provides constant suction and will remove more oil than using the drain plug (if you move the tube around a bit near the end of the extraction). Any air compressor will work with the 7300, even the smallest and cheapest ones (although most of the very small ones require a 12 volt cigarette lighter power source).
    https://www.amazon.com/gp/product/B0...=ATVPDKIKX0DER
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Need products for your Hyundai Genesis? Check out your options at the links below:
