Sign up to remove ads. We'd love to have you amongst our ranks! Just click the Register button below!
genesis motors forum   genesis motors forums
Direct Links: Genesis Motors Brand | Genesis G70 | Genesis G80 | Genesis G90 | Genesis Sedan | Genesis Coupe | Equus
Genesis Forum: (#easy) You want a LED DRL on your US Genesis? Read on.
Page 7 of 9 FirstFirst ... 56789 LastLast
Results 61 to 70 of 86
  1. #61
    2015g5.0 is offline Registered Member What I drive: 2G Genesis 5.0 V8 Ultimate
    I live in Washington, DC
    Join Date
    Oct 2015
    Posts
    48
    Cars in my garage
    Rep Power
    Default Re: (#easy) You want a LED DRL on your US Genesis? Read on.
    Members don't see this ad
    I have been looking all over for this THANKS! Can/Could you describe how to do this without pulling the bumper. Thanks! Or if you know of anyone who has/can do this in DC.
    - - - Updated - - -
    So the amber driving lights continue to run as DRL in Auto mode and the accent/parking lights burn bright when in Parking light mode or headlight on mode?
    - - - Updated - - -
    Quote Originally Posted by Dthomas1 View Post
    I have been working on this and a relatively simple semi fix is available for US cars. As reported in this thread, a wire is missing in the connector on US versions. Unfortunately, there is NOT a wire on the corresponding plug on US versions like the Canadian version. By removing the center brown wire and moving it to the empty spot on the connector, the parking lights will then be the brighter version of the lights. The only caveat is that you must turn on the parking lights but it is awesome to have the bright LED eyebrows.
    So you just move the brown wire to the empty slot on the same connector? as indicated in the pics above?
    Mfg Date: 2/24/15
    Parisian Grey V6S
    Ivory Trim VYC
    Black Card #304
  2. #62
    Dthomas1 is offline Registered Member What I drive: 2G Genesis 5.0 V8 Sedan
    Join Date
    Jul 2016
    Posts
    15
    Cars in my garage
    Rep Power
    Yes
  3. #63
    Dat5.0GenLyfe2016 is offline Registered Member What I drive: 2G Genesis 5.0 V8 Ultimate
    Join Date
    Feb 2016
    Age
    29
    Posts
    80
    Cars in my garage
    Rep Power
    2
    I just wanted to say that I just did the switch, easy super easy and they are much brighter.. Once you put it in Auto mode they go back to low light.
    Update: now for some reason I don't have fogs working???? has anyone with the tech package with fogs that have done this mod, have the same problem???
  4. #64
    tuckerdog1's Avatar
    tuckerdog1 is online now Been here awhile... What I drive: 2015 2G 5.0
    I live in TEXAS
    Join Date
    Jan 2017
    Posts
    101
    Cars in my garage
    Rep Power
    Couple questions:
    If, say an Audi is coming at me with it's LED DRLs on, and a turn signal is turned on, the LED DRL on that side of the car turn off until the turn signal is turned off. On a 2016 Genesis that "comes" with the LED DRLs, does that happen? And once this change is made to a 2015, if the turn signal is turned on, do these LEDs that are now the DRLs turn off?
    Tuckerdog1
    In my Genesis garage: 2015 Hyundai Genesis Sedan
  5. #65
    jrhodes87 is offline Registered Member What I drive: 2G Genesis 3.8 V6 Sedan
    Join Date
    Aug 2016
    Posts
    107
    Cars in my garage
    Rep Power
    Quote Originally Posted by tuckerdog1 View Post
    Couple questions:
    Tuckerdog1
    Yes the LED DRL will turn off on the 16 genesis the turn signal will become a small amber blink. Unless you purchase OEM Korean Domestic (dual projector) Genesis or G80 head lights, then the entire DRL will blink amber, looks much better imo.
    http://www.ebay.com/itm/LED-Genuine-...3D282307826414
    http://www.ebay.com/itm/LED-Headlamp...3D321988117426
  6. #66
    sunnyjim is offline Hasn't posted much yet... What I drive: Nevada
    I live in Nevada
    Join Date
    Dec 2016
    Posts
    2
    Cars in my garage
    Rep Power
    srobak,
    So if I am understanding you, without doing this "brightening" work on the headlights (bumper removal, electrical, etc.), I could just manually turn on my LED parking lights to use as running lights in the daytime, and then switch to regular lights for night driving? Untalented as I am, that would still be an improvement over the amber DRLs. Right? Tks.
  7. #67
    namorbrowneyes is offline Registered Member What I drive: 2G Genesis 3.8 V6 Sedan
    Join Date
    Jan 2016
    Posts
    38
    Cars in my garage
    Rep Power
    Can someone confirm if after doing this mod, the side amber accents (triangular) no longer light up when switching the knob? Mine aren't a lighting anymore ... Is this due to moving the wire over at the plug??
  8. #68
    Join Date
    Jul 2016
    Posts
    15
    Cars in my garage
    Rep Power
    Yes, they no longer work due to switching the wire.
  9. #69
    Join Date
    Jan 2016
    Posts
    38
    Cars in my garage
    Rep Power
    Thanks for confirming sir
  10. #70
    Join Date
    Jan 2016
    Posts
    38
    Cars in my garage
    Rep Power
    I'm looking at taking this a step further, since I don't have a spare headlight laying around...and I would like the side amber triangle to work.
    This looks like the same male pin if I remember correctly. Anyone agree with me on it working?
    https://www.sparkfun.com/products/10501
    Edit: I may even tap off that middle wire into the open port with an additional wire and pin instead of running the additional wire back through the plug.
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Need products for your Hyundai Genesis? Check out these options below:
Check out what the competition is up to. The Kia Stinger is a large sport-oriented hatchback in the mold of the Audi A7.
