Registered members do not see this advertisement! Remove it by signing up for free.
Genesis Forum: Proximity key - Anyone know what happens if you walk away while engine is running?
Results 1 to 5 of 5
  1. #1
    Canadian is offline Registered Member What I drive: 3.8 V6 Sedan
    I live in Ottawa, Ontario
    Join Date
    Dec 2008
    Posts
    41
    Cars in my garage
    Rep Power
    Default Proximity key - Anyone know what happens if you walk away while engine is running?
    Members don't see this ad
    On several occasions, I've gotten out of the car (3.8 sedan) with the key in my pocket. There is long beep audible inside and outside the car. But what happens if I keep walking? Recently, I almost let my brother-in-law drive away while I had the key in my pocket. Would the car run until he turned off the ignition and then he'd be stranded? Would it stall after a certain distance or elapsed time? Anyone tested this yet?
  2. #2
    Dimitry is offline Registered Member What I drive: 2G Genesis 5.0 V8 Ultimate
    Join Date
    Feb 2009
    Posts
    420
    Cars in my garage
    Rep Power
    Default Re: Proximity key - Anyone know what happens if you walk away while engine is running
    It keeps going. And going.
    I learned this when the valet drove away without my keys once
  3. #3
    STREETS is offline Registered Member What I drive: Genesis 3.8 V6 Sedan
    I live in Connecticut
    Join Date
    Jul 2009
    Age
    52
    Posts
    799
    Cars in my garage
    Rep Power
    The car will BEEEEEEEP for about 10 seconds alerting you that you or another person is leaving with the key- and car is still running.
    Owner Genesis 3.8 TECH White/Cashmere with Genesis Wing replacement inside-out, LEDs
  4. #4
    JOwest is offline Registered Member What I drive: 4.6 V8 Tau Sedan
    Join Date
    Sep 2008
    Posts
    300
    Cars in my garage
    Rep Power
    9
    The engine will continue to run after the beeping and the car can be driven like normal until someone turn off the engine. It won't start again without the key. It will say "Key not in car".
  5. #5
    Mark_888 is offline Registered Member What I drive: 1G Genesis 3.8 V6 Sedan
    Join Date
    Jan 2009
    Posts
    10,792
    Cars in my garage
    Rep Power
    19
    Quote Originally Posted by JOwest View Post
    I guess that feature comes in handy if one is the victum of a car-jacking.
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Need products for your Hyundai Genesis? Check out your options at the links below:
