Registered members do not see this advertisement! Remove it by signing up for free.
Genesis Forum: Sedan Subwoofer install
Page 9 of 9 FirstFirst ... 789
Results 81 to 84 of 84
  1. #81
    Von888 is offline Hasn't posted much yet... What I drive: 2G Genesis 3.8 V6 Ultimate
    Join Date
    May 2016
    Age
    43
    Posts
    Cars in my garage
    Rep Power
    Default
    Members don't see this ad
    How did you install the Video In Motion in a 2015 Genesis Sedan.? How much did it cost? Thank you in advance.
    QUOTE=MathWiz;196854]I finally was able to install mine over the weekend
    Added the LC2i from AudioControl along with the subwoofer level control. This has signal sensing turn on for the amp.
    Added a Alpine MRP-M500 - Amplifier - 1-channel
    Product Features
    RMS Power Per Channel Into 4 Ohms: 300W X 1
    RMS Power Per Channel Into 2 Ohms: 500W X 1
    2 Single Voice Coil Subs Or 1 Dual Voice Coil Works Best
    Number 1 Rated Amp In The US
    and the 2 10" JL Audio subs I took out of the car replaced by the Genesis.
    Fills in the bottom end nicely.
    I added the Video in Motion (VIM) interface from NavTV so that DVDs can now be shown with the car moving.
    Charles[/QUOTE]
  2. #82
    Join Date
    May 2016
    Age
    43
    Posts
    Cars in my garage
    Rep Power
    Default Re: Sedan Subwoofer install
    I was able tominstall everything.
    Several ive encountered.
    1. I tappedto the subwoofer connector. If the volume is low, the LC2 i will not power on as well as the amp. It has to be in middle or halfway to power it using GTO. The power cuts off depending on the music.
    2. If the music is off, i get a very loud hissing on the subwoofer. Really loud.
    3. I barely notice the bass. The 2015 Genesis Sedan Ultimate Tech Package has a very good sound insulation that you dont hear the aftermarket sub. But if the trunk is open, i can feel the bass and the vibrations on low freq.
    Any input will be highly appreciated. Thank you in advance.
  3. #83
    iSOBigD is offline Registered Member What I drive: Genesis 3.8 V6 Sedan
    Join Date
    Jun 2015
    Age
    32
    Posts
    159
    Cars in my garage
    Rep Power
    2
    Quote Originally Posted by Von888 View Post
    You're pointing speakers away from car, so it's normal for sound waves to travel away from you and outside the car through the trunk, bumper cover, etc. The back seats have thick foam behind them and some metal/plastic, then some type of felt layer all over the trunk. If you're sitting in the front of the car, you have even more layers to block the sound (4 seats, absorbing materials like the carpets and headliner material) that's why the stock sub is pointed up right into the car.
    I think for best results, even with just one smaller sub instead of 2 big ones, you'll want to simply replace the stock one, or use that same opening (or another one like the pass-through between the back seats).
    Outside of that, any way you slice it, even if you get 10x the volume so that you can feel it better inside the car, you'll be wasting most of the sound which kinda goes against the point of good soundproofing in order to get good sound.
    2012 Genesis 3.8 - Premium, Tech, Nav - Genesis Soundproofing Thread
  4. #84
    Join Date
    Feb 2017
    Posts
    11
    Cars in my garage
    Rep Power
    Quote Originally Posted by Platinum 09 View Post
    Its very difficult to tell what kind of output (RCA or low level) that you could even use to tie into an aftermarket amp/sub.
    You find the V8 with Tech stereo not to your liking in terms of the bass?
    I have the 17 speaker lexicon system in 2014 r spec...although system sounds great....some ppl including me always want more...just the way it is...upgrading turns me on....grrrr
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Need products for your Hyundai Genesis? Check out your options at the links below:
