Sign up to remove ads. We'd love to have you amongst our ranks! Just click the Register button below!
genesis motors forum   genesis motors forums
Direct Links: Genesis Motors Brand | Genesis G70 | Genesis G80 | Genesis G90 | Genesis Sedan | Genesis Coupe | Equus
Genesis Forum: Oil Change DIY - 3.8 V6 Genesis Sedan
Page 6 of 8 FirstFirst ... 45678 LastLast
Results 51 to 60 of 79
  1. #51
    upsbroke is offline Registered Member What I drive: Genesis 3.8 V6 Sedan
    I live in Kansas
    Join Date
    Jul 2011
    Age
    62
    Posts
    227
    Cars in my garage
    Rep Power
    6
    Default Re: Oil Change DIY - 3.8 V6 Genesis Sedan
    Members don't see this ad
    bump for the answer
  2. #52
    Southern Boy's Avatar
    Southern Boy is offline Registered Member What I drive: Genesis 3.8 V6 Sedan
    I live in West Central Coast Florida
    Join Date
    Dec 2011
    Age
    73
    Posts
    391
    Cars in my garage
    Rep Power
    6
    A little off subject, but close enough.
    This is an interesting article that speaks to the need to change oil at what frequency and also addresses from plain dino oil to fully ester synthetics and semi-synthetics and so called 'synthetics' made from base stock oils.
    http://www.edmunds.com/car-care/stop...-your-oil.html
    I must admit that the 3000 mile change has been my MO since my first car. I still have a problem running oil as long as is suggested in this article. Old habits die hard.
    2011 Genesis Sedan 3.8 V6
    Titanium Gray Metallic
    Black leather
    Chrome pillars, Chrome door trim
    Wings hood & trunk, Wings wheel caps
    TSW Sentterton Chrome 18X8 40mm offset Wheels
    General G- Max AS03 225/50ZR18 Tires Nitrogen fill
    Southern Life Philosophy:
    Faster Cars, Younger Women, Older Whiskey and More Money!
  3. #53
    Philth is offline Been here awhile... What I drive: Genesis/Equus In His/Her Dreams (Doesn't own one yet)
    Join Date
    Feb 2012
    Posts
    811
    Cars in my garage
    Rep Power
    6
    Default Re: Oil Change DIY - 2012-3.8 V6 Genesis Sedan
    Quote Originally Posted by upsbroke View Post
    Does the oil filter housing on the '12- 3.8 use a large o-ring seal that fits on the cap that seals for leaks against the housing?
    Yes. Same filter part number as older years, but there is no smaller tube on the inside. Because of that, discard the smaller o-rings.
  4. #54
    I live in Kansas
    Join Date
    Jul 2011
    Age
    62
    Posts
    227
    Cars in my garage
    Rep Power
    6
    Quote Originally Posted by Philth View Post
    Thank you very much!
  5. #55
    decan9 is offline Getting familiar with the group... What I drive: Genesis 3.8 V6 Sedan
    Join Date
    Aug 2011
    Posts
    49
    Cars in my garage
    Rep Power
    Quote Originally Posted by Southern Boy View Post
    when I was a kid in the 30's you were supposed to change oil every 1000 miles. Then a company called Kendall advertised a 2000 mile oil!!!
  6. #56
    Join Date
    Dec 2011
    Age
    73
    Posts
    391
    Cars in my garage
    Rep Power
    6
    Quote Originally Posted by decan9 View Post
    Well I go back to the early 50’s when I was at a point to remember all those add on oil filters for cars that had no filter at all?
    I remember one add on filter that used a roll of toilet paper inserted in to a canister to filter the engine oil.
    I remember engines that lasted 60K miles was thought to be about all you could expect, and engines that lasted 100 K was something exceptional and that burning leaded gasoline caused the mufflers and tail pipes to rot away in 30K miles. Man those were the “good old days”, yea right
  7. #57
    spark763 is offline Hasn't posted much yet... What I drive: Genesis 3.8 V6 Sedan
    Join Date
    Feb 2013
    Age
    46
    Posts
    10
    Cars in my garage
    Rep Power
    What is the part number for the 2013 3.8 oil filter? I ordered filters on-line and the Hyundai box # 26320 3c30a, but stamped on the filter is, Mahle 26330 3c300. Very confusing, was going to order the Mobil 1 filter, but want to use the OEM filter so there is no problem with a warranty claim. I will see in a few weeks when I change the oil at 3000 if I have the right filter. After changing at 3000, I am going to change every 6000 with Mobil 1 5w30.
  8. #58
    Mark_888 is offline Registered Member What I drive: 1G Genesis 3.8 V6 Sedan
    Join Date
    Jan 2009
    Posts
    11,401
    Cars in my garage
    Rep Power
    20
    Quote Originally Posted by spark763 View Post
    If it is a Mahle filter with white end caps, I think it is the correct filter. The part number on the box is a "kit" that incudes other parts (o-rings), plus the filter part, hence the different part number on the box.
  9. #59
    Celt is offline Hasn't posted much yet... What I drive: Genesis 3.8 V6 Sedan
    Join Date
    Feb 2013
    Age
    55
    Posts
    Cars in my garage
    Rep Power
    I have changed the oil in a Mercedes E320 for years. Just moved over (up?) to the genesis. It has the same oil filter location and type. I have always found it soooo much easier to simply pour the new oil in the giant gaping hole before replacing the new filter. Zero spills.
    Nice write up.
  10. #60
    Join Date
    Jan 2009
    Posts
    11,401
    Cars in my garage
    Rep Power
    20
    Quote Originally Posted by Celt View Post
    Nice write up.
    I assume you have a 2009-2011 Genesis V6 with the oil filter on the top. The 2012+ V6 (plus all V8's) have the filter on the bottom of the engine, and I have always found it a bit clumsy to turn the car upside down in order to pour oil into the oil filter compartment.
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Need products for your Hyundai Genesis? Check out these options below:
Check out what the competition is up to. The Kia Stinger is a large sport-oriented hatchback in the mold of the Audi A7.
