Become a registered member for a cleaner interface and faster page loading! It's free!
hyundai genesis sedan   hyundai genesis sedan
DIRECT LINKS: Genesis Motors | Genesis Sedan | Genesis Coupe | Dealer Reviews | Invite a friend!
Go Back   Genesis Motors Forum > Hyundai Genesis Sedan Forums - 3.8 V6, 4.6 V8, 5.0 R-Spec V8 > General 2009-2014 Hyundai Genesis Sedan Discussion
Hyundai Genesis Forum / Magazine Advertise Help us help you! Calendar Today's Posts
Notices
General 2009-2014 Hyundai Genesis Sedan Discussion Forum for discussions regarding the Hyundai Genesis Sedan that don't fit specifically anywhere else.
Hyundai Genesis Forum: 4.6 Oil Filter Location (Pics)
Reply
Thread Tools
  #1
Old 01-17-2009, 11:51 PM
DesertGen DesertGen is offline
Drives a Hyundai Genesis 4.6 V8 Tau Sedan
View DesertGen's Photo Album
DesertGen is on a distinguished road
Default 4.6 Oil Filter Location (Pics)
Remove this ad
I decided to get up close and personal with the Genny today. I wanted to see the oil filter location for myself. It is really not too hard to get too, although you do have to lift the front end up.
The lower engine cover has 8 - 10mm bolts and one Phillips head plastic anchor screw holding it in place. Remove them all and you are home free. I circled the bolt positions in red and the anchor screw in yellow on the "4.6 Lower Engine Cover" pic. Also see the "Anchor Screw" pic to see what it looks like installed.
As you can see from the "4.6 Oil Filter Location" pic it is in front of the oil pan at the front of the engine. The composite filter cap is marked 25mm, so you will need a socket this size, or you could probably get away with an adjustable wrench (although that could get sloppy). The "Oil Filter Body" pic gives you a different view.
Lastly, the oil drain plug can be easily reached through an access port in the cover (Oil Drain Hole pic), but this doesn't make any sense since you have to take the cover off to get to the filter. I've known some individuals who only changed their filter every other oil change, but for me the cost of the filter is not so expensive that I wouldn't want to change it every time.
The oil filter part number for the 4.6 is 26320-3C100 which can be found as a part for a number of Kia and Hyundai cars online. As for cost, Hyundai Parts Net has the filter for $5.31. Hyundai Parts Direct lists at $5.21. Of course, if you buy online you will pay for shipping (no tax), so even if you buy 6 filters, by the time you add shipping you are looking at close to $7.50 each. For that cost you are probably going to do just as well at the dealer.
As a final observation, it was a pleasure to get a good look under the Genesis. It is a well designed and well executed car. Seeing the thoughtfulness that went into the design gives me a lot of confidence in the potential for this car to last a long time!
Click image for larger version
Name:	4.6 Lower Engine Cover.jpg
ID:	264   Click image for larger version
Name:	Anchor Screw.jpg
ID:	265   Click image for larger version
Name:	4.6 Oil Filter Location.jpg
ID:	266   Click image for larger version
Name:	Oil Filter Body.jpg
ID:	267   Click image for larger version
Name:	Oil Drain Hole.jpg
  #2
Old 01-18-2009, 01:47 AM
ConceptVBS ConceptVBS is offline
Drives a Hyundai In His/Her Dreams (Doesn't own one yet)
View ConceptVBS's Photo Album
ConceptVBS is on a distinguished road
Default Re: 4.6 Oil Filter Location (Pics)
Thanks for the pics!
Hmm.. thats an interesting looking filter. I've never seen those before. Wow, it looks like the undercarriage of the Genesis is well sealed. Hyundai tested this vehicle extensively in the wind tunnel and it definitely shows.
  #3
Old 01-18-2009, 09:19 AM
Mark_888 Mark_888 is online now
Drives a Hyundai 1G Genesis 3.8 V6 Sedan
View Mark_888's Photo Album
Mark_888 will become famous soon enough
The actaul filter that you purchase is only a cartrdige and what you see is the housing.
  #4
Old 01-18-2009, 10:41 AM
CRUBOS CRUBOS is offline
Drives a Hyundai 4.6 V8 Tau Sedan
View CRUBOS's Photo Album
CRUBOS is on a distinguished road
Desert Gen,
Thanks for the pics, awesome job
  #5
Old 01-18-2009, 03:44 PM
ctrcbob ctrcbob is offline
View ctrcbob's Photo Album
ctrcbob is on a distinguished road
Is that a drain bolt (allen head) on the bottom of the Oil Filter Body?
If it is, the Oil Filter Body can be drained before you take off the filter cap. If that is not a drain bolt, there is going to be a big mess when you remove the filter cap to change the filter. (What size allen head?)
Although I have no intention of changing my own oil, and filter, I'm going to make sure I have a 25mm socket, just in case.
__________________
Bob CTRC
USN Ret.
Mount Dora, FL (It Could Be Worse)
Penfield, NY (A Quiet Rochester Suburb)
Roswell, NM (Alien Central)
09 Genesis 4.6 Tech (Sold)
10 SHO Ecoboost Twin Turbo
11 MKZ
  #6
Old 02-08-2009, 09:53 PM
Did the first oil change today at 2k (I prefer to do the first one early in the break-in cycle). Changed to M1 5w30.
A couple of things I discovered:
The 25mm that I thought I saw on the filter cover actually says 25nm, meaning newton meters (of torque). The actual nut size is 27mm as someone else had stated. You will need a socket to do this, don't bother trying to use a cresent wrench cause it just slips off.
As noted in one of the pics I posted, the filter housing has a 6mm allen head screw, which is in fact a pre-drain plug. Very useful for this type of filter. I was able to drain nearly all of the oil before removing the filter.
The actual part number for the 4.6 filter is 26320-3F100 (although the dealer was even uncertain about this - yikes!). The kit comes with replacement o rings for both the filter cap and the allen screw. I paid 8.53 with tax.
Draining the oil from this car is interesting. The pan bolt is on the side of the pan, so when you take it out the oil just gushes out in a sideways arc a good foot away from the pan. Gotta watch where you place your drain pan or you'll have oil all over the floor, as I did.
  #7
Old 02-08-2009, 10:53 PM
Quote:
I believe that the filter cartridge is the same for both V6 and V8, but V6 filter is on top of engine and it naturally drains back into the engine (pics are in another thread). I picked up a V6 cartridge that has the same part number (although the parts guy originally tried to give a traditional metal filter).
Not sure, but the oil pump and filter system may be from this company:
http://www.hengst.de/conpresso/_rubr...dmanagement_EN
  #8
Old 02-09-2009, 12:34 AM
The replacement filter is stamped "Mahle 26330-3c300" which leads me to believe the filter system is from this company:
http://www.mahle.com/C125705E004FDAF...6LG8T186WEBBEN
  #9
Old 02-16-2009, 07:06 PM
Does anyone know if a 27mm 12-point socket will work, or does it need to be 6-point (like the actaul nut)?
I have the V6 but both engines use the same filter.
  #10
Old 02-16-2009, 07:16 PM
Blackout's Avatar
Blackout Blackout is offline
Drives a Hyundai
View Blackout's Photo Album
Blackout is on a distinguished road
Interesting. This is the first set of pics I've seen of the underside of the Genesis and I'm impressed with it having true duals instead of like on my old Lincoln Mark VIII a single pipe with two pipes to make it look like it's a true dual setup
Reply
Bookmarks
Download the Cars Connected app
Tags
46, filter, location, oil, pics
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Hyundai Genesis Ads
Remove this column
My Pledge
buy a genesis winged badge emblem
cars connected social network cars connected social networking app for ios cars connected social networking app for android
Powered by vBulletin® Version 3.8.9
Copyright ©2000 - 2016, vBulletin Solutions, Inc.
GenesisOwners.com recognizes that "Hyundai", "Genesis" and "Genesis Motors", it's logos and various model names and numbers are registered trademarks of the Hyundai Motors Corporation. These terms are used for identification purposes only. GenesisOwners.com is not affiliated in any way with the Hyundai Motors Corporation, Hyundai or any other company listed herein. All information on this site is the opinion of its members and not the opinion of the site itself. 2015 Madison Ross Media Group. All rights reserved.
Need products for your Hyundai Genesis? Check out your options at the links below:
