Glassman
So I finally got a chance to throw my 4.6L on the dyno at my office tonight. I posted recently about a track outing that the car ran a conservative 14.2 as I didn't want to push it to the limits on the launch and was asked if I can get some dyno results since I have easy access to a dyno and haven't gotten around to modifying the engine at all yet so we can get a solid baseline for what the 4.6 will push out. So long story short I had runs measuring in between 296 and 315 just depending on how the trans and ECU hooked up each run with being confused on the dyno, one of my company's in house tuners was saying that the car was messing with the torque converter's output since I only set it up for the rear tires to roll and it was throwing all sorts of ABS and ESC lights. So after combing through a couple runs dialing the car in to where it likes to be on the dyno we got what we feel was the most realistic idea of actual output to the rear wheels. One run with 308hp and 295 ft/lbs and another at 311 hp and 293 ft/lbs The cars gets a little funky around 4500 rpm when it is deciding what to do with the engine's timing which is easy to see on the graphs. The following pulls were a 4th gear run and a run through 3rd and 4th
