Genpire
- Sep 29, 2014
Just a heads up and an inquiry to others.
When I grab the steering wheel like I'm going to use the paddle shifters and I pull towards myself one side at a time, the steering wheel shifts back and forth as though a bolt is coming loose. It does it in park or while driving, doesn't matter.
the rubber seal between the sunroof and the rear passenger glass is coming loose from the rear passenger glass, so that when the sunroof closes the seal is pushed down at a 45 degree angle. I have checked others on the car lot and they are not that way, so maybe the glue/bond has failed on mine.
just a heads up and inquiry to see if others have had this issue.
I plan to take it in soon for service.
