I'd like to preface this with a disclaimer that I am not suggesting or recommending that anybody perform modifications to their Genesis's lighting system that would render the car less safe or illegal to drive on public roads.
There are a few situations where disabling DRLs is not only recommended but an obligation, such as for drivers who frequently drive on military grounds.
Thankfully it appears that disabling DRLs on the Genesis is a very easy affair. All one has to do is to pull the DRL fuse located in the driver-side under-hood sub-fuse panel. This is a blue 15A fuse which is labelled "DRL" in both the owner's manual and under the fuse box cover. I've highlighted the location of that fuse in the following diagram:
After a few tests in my driveway (longer-term tests to follow) it appears to completely disable the DRLs without affecting the operation of the high beams (same bulb) and without causing any idiot lights or error message to be displayed on the dashboard.
