I love driving this car but with the hot summer here and some heavy braking in spirited driving to and from work. I decided to upgrade the front pads and rear rotors with pads. I looked around, researched companies quite a bit before I settled on Power Stop.
For the front, at this time I kept the OEM rotors but installed new pads. The front brake pads were one of the easiest I've ever done. Their almost like a quick change. See pic. It took longer to figure out where to put the jack and pull the wheel than to change the pads. I bought the Power Stop (Z23-1396) Z23 Evolution Sport Brake Pads, Front. You immediately notice the pad surface area is significantly increased compared to the OEM pads. See pic.
The rear brakes actually took longer. The tricky part for me was convincing the electric parking brake to release long enough to swap the right rear rotor. I bought the Power Stop (K5848) 1-Click Brake Kit, which included the cross drilled and slotted rotors with their Z23 Evolution Sport Brake Pads.
I followed the instruction on bedding in the brakes. I've got about 125 miles on them now and it seems like they keep getting better and better the more I drive. Certainly a big improvement when higher speed braking and normal braking.
