Many car alarms detect trunk or hood opening as "break in attempts" - ONCE those are closed. You wouldn't want the alarm to trigger when you closed the trunk right after parking the car, right? (park car, open door & trunk, get out, close door, lock it, get your briefcase out of the trunk, close trunk. Ideally the alarm is "armed" now, not sounding!) Hyundai's manuals call this the "ARM HOLD" state: the alarm is ready to ARM but won't ARM until all doors, the trunk, and the hood are actually closed.
A lot of the Genesis electronics stuff "wakes up" whenever it thinks the driver is nearby. Note how long the "Genesis" splash screen displays on the nav display for the following scenarios:
#1 car is parked but not locked (in your garage I hope!). So the first time the car gets a hint you're nearby is when you actually grab the door handle and open the door. Or if you open the trunk.
#2: car is parked and locked. You use the key fob to remotely unlock the car (or to remotely pop the trunk) while you're still walking to the car. It'll start it's "wake up" stuff at this point; you may notice the nav system is ready much sooner than scenario #1.
#3: car is parked & locked. You unlock it by the key or by pressing the door handle button instead of using the key fob remote, or you use the key to open the trunk. Again, the car doesn't know you're nearby until you actually unlock it.
Having any door open, the hood, or the trunk open is interpreted as "driver is nearby" to the system so OFF stuff may power up to the "standby" level instead. Standby = ready to turn ON quickly if you return to the car quickly after shutting the car off (e.g. running into 7-11 or Starbucks for a moment). The battery apparently can support this "standby" mode for a day or two based on other threads. After the car really has been parked a while the electronics shut down fully - just the alarm, clock, and various memories are powered The battery can support this for a few weeks at least. Cars missing the hood switch rubber piece likely never leave the "standby" mode because the alarm sees "hood/trunk is open... driver must be doing something... I'll wait for the hood/trunk to close before I fully power down and really ARM the alarm."
The hood switch is described in chapter 13, the "Body Electrical System" section, of the factory service manuals. It's listed in the section describing how the factory alarm system operates.
mike c.
