Gold Z
On my 3.8 the cruise control varies by as much as 3 mph faster or slower than the set speed. My dealer is no help. Does anyone else have this problem?
The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Genesis parts & accessories
Advertise with us!
Advertise with us!
It's fine on flat roads. It only does it on slight hills.
There is not much difference between 6% and 6 degrees because there are 90 degrees in a right angle. 6 degrees is 6.66% angle.Page 5-28 of your owner's manual states that the cruise should only be used on roads with less than a 6% grade. That would seem like a "slight incline". 6% is different than 6deg. A 6% grade means that the road level rises (or falls) 6ft vertically for every 100ft of horizontal distance (100.1798ft of road travel). As you can see this is a very small angle, roughly 3.4 degrees. The manual also states that the car may speed up or slow down on larger inclines. It sounds like your system is working as intended. I hope this helps.
I noticed this also, but wasn't sure if it was my imagination. My default driver information is set to show the current MPG and with careful driving it seems that one can achieve good gas mileage with the Genesis (if the display is accurate).I have noticed that this car "coasts" much more than any other car I have owned.
What??? When I talked to the salesman about the Genesis, he specifically promised me that there was no math required to drive the car!!!Not quite. A 100% incline (for example, 100 foot drop over 100 foot of horizontal travel) is a 45 degree angle.
I have experienced this same issue. It is noticably worse that other cars I have driven, foreign or domestic. Its Ok on level road but any incline will cause the speed to drop off before the system starts to compensate. This ought to be a calibration issue that could be fixed with a firmware upgrade, but is probably beyond the Dealer level and will require a TSB from Hyundai.
From a horsepower to weight ratio perspective, even the V6 Genesis ranks higher than the majority of cars.One thing I would ask is: how heavy were those other cars you're comparing against? The Genesis is fairly heavy at 4k lbs and that will have a effect on just how well the cruise control can hold speed on inclined roads.
