The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Genesis parts & accessories
Advertise with us!
Advertise with us!
Website appears to be "parked" by Go-Daddy.You might try this site www.detailimage.com for advice and reviews of all car waxes and products use by professional detailers.
Thanks for all the information. Sounds like NXT is popular. Over at the Mercedes blog they like it too. Anyone use Zymol? I used it on my Porsche and it lasted forever. I still have some that I kept in the refrigerator. Hand packed Carbon wax?
Looks to me like Zymol is a true wax product (not synthetic polymer) so it may look great, but won't last nearly as long.I have used Zymol and its very good, still have an old bottle in my shop. However the Nu finish lasted longer for me. The NU-finish liquid is not very abrasive and their spray is not abrasive at all. Check consumer reports tests, that also may help you deside.
One of the problems I had with advice from "professional detailers" is that they often use products that are buffed with professional buffing machines, and that is not something most car owners want to do for themselves.
Actually, Mark, your post has plenty of mythology and opinion, much of which I used to share until I got schooled. Meguiar's reps on their discussion site will tell you that as long as the paint is properly prepped (wash, clay, cut, polish before waxing), the wax selected does not matter, as it's just a protective layer. Meguiar's carnauba waxes (#26 Yellow and Gold Class) last perhaps a week or so less than the synwaxes (Ultimate or NXT, for example), or about a month. That is all anyone need expect from a wax, as it's not meant to be permanent. However, a boost wax like their "quick wax" matched to the wax type (Ultimate for synthetic, or Gold Class for carnauba) used after washes or quick details will extend the wax application for a much longer time, as will avoiding washes when a quick detail will do, so the "correction" process might only need doing two or three times a year. The carnauba waxes will look deeper and richer by comparison, and both claying and true polish (Ultimate Polish) are non-abrasive, so you can do them anytime you wax. It's the cutting/leveling with compound that can be mildly abrasive. However, if you use Ultimate Compound and a Mirror Glaze cutting pad for a dual action machine, there is no danger of paint damage.Car Wax generates a lot mythology and very strong emotional opinions, but it is very hard to find the actual facts.
I will stand by my original post. I use Meguiar's myself (Cleaner Wax and NXT), but I don't believe:Actually, Mark, your post has plenty of mythology and opinion, much of which I used to share until I got schooled. Meguiar's reps on their discussion site will tell you that as long as the paint is properly prepped (wash, clay, cut, polish before waxing), the wax selected does not matter, as it's just a protective layer. Meguiar's carnauba waxes (#26 Yellow and Gold Class) last perhaps a week or so less than the synwaxes (Ultimate or NXT, for example), or about a month. That is all anyone need expect from a wax, as it's not meant to be permanent.
No, true polishes are non-abrasive, merely creating a bright shine a wax then adds to and protects. A polish like Meg's Ultimate Polish can be used everytime you wax with no ill effects whatsoever (assuming it's applied correctly). Quality compounds, like Meg's Ultimate Compound, are also very mild micro-abrasives (SMAT) that you'd have to go well out of your way to do any harm with, like using lots of pressure and staying a long time on one spot on a plastic painted bumper, for example. Otherwise, it can be used everytime you wax, though it might not be necesary, depending on swirls, etc....A true car polish is not something you want to use on a regular basis since it actually removes a very thin layer of the clear coat or paint (although not nearly as much as rubbing compound, which should only be used once on a very old and oxidized paint service)...
Misleading. Paint on new cars is already cured by the time we buy them, and (although I haven't used MCW in a long while) you can use such a product every single time, and probably need to if all you're otherwise doing is old school waxing, because just washing and waxing will not be good enough after a few months to a year of gunk building up on a daily driver non-garaged, especially if you're only waxing once a year because you think wax lasts that long...Meguiar's Cleaner Wax...probably [does not] need to [be] used on a continuous basis for the life of your car (unless used sporadically). Probably OK to use a product like this one time when the car is new (after paint has cured) and then follow-up with a traditional wax product after that.
Well, there is less real difference visually between any wax compared with another, even on a black car, than some people seem to think. The real differences are in the prep or condition or polish of a panel or area. It also depends greatly on what "detergent" you're talking about....Most decent modern car waxes no longer actually contain natural waxes, but are actually synthetic polymers. True waxes (especially carnuba wax) are typically only used on show-cars to provide visual depth, but they don't last very long and are easily removed with a detergent...
Misleading. It sounds like you are talking about those dealer sealants which are more akin to clear coats, and that is not the same thing at all as a synthetic wax....Synthetic polymers have sealant properties and have the ability to physically bond to the paint or clear coat that most people are looking for, and last a reasonably long time. They are so hard to completely remove (unlike a true natural wax), that body shops have to use special chemicals to remove it when repainting a car.
Sorta, as least with Meguiar's. Quick Detailer is a non-abrasive cleaner-polish for water-less washing, Quick Wax is a non-abrasive booster for the proper wax, and both should be matched to your wax's product line, as you said....One-step sprays are typically used on a wet car (right after a car wash but before it is dry), but these typically don't last as long as the kind you apply, let dry, and wipe off. But they may be OK in-between regular waxing, especially if it is the exact same brand/formula of liquid or paste wax that you used previously with traditional application methods.
You no longer need a rotary buffer to get that look (which carries more risk of paint burn). You do need a 3-step process, though, and a DA is definitely the way to go. I remove product and buff by hand, although, I might get a buff pad here soon. Still, professional detailing advice is not something to ignore just because you don't want to use a machine (if I understood you, correctly). Some detailers can surely be wrong about a lot, but I've been very impressed with the Meg's forum....One of the problems I had with advice from "professional detailers" is that they often use products that are buffed with professional buffing machines, and that is not something most car owners want to do for themselves.
Yes, Gold Class is a blend, some others aren't. Some people in the forums report NXT lasting as little as 3 weeks and Deep Crystal as long as 6 months, and of course, the reverse, and so on. Again, it totally depends. I'd used a synwax before (First Place Finish) and it only lasted a few weeks at best, but then I was washing a lot. I've used others over the years, and not washed as much, and never got anything like a year out of them as you're claiming. Now, the basic polish or finish itself (not the wax) can certainly last a long time. I mean, if paint is in great condition and washed with a quality wash-n-wax soap, you can sometimes barely tell the applied wax has actually worn off. I really don't think anyone is getting a year out of any wax job, unless it's a garage-kept car under a soft cover that only comes out for a few hours at a time and thus never needs much actual cleaning...I don't believe:
- That a carnauba wax will last nearly as long as synthetic. Perhaps Meguiar's carnauba waxes are blends of carnauba and synthetics, and they last longer than pure carnauba.
- That a good quality synthetic wax lasts only about 5 weeks as you imply above. Most good synthetic car waxes will last up to year, depending on how often they are washed and what kind of wash detergent is used.
Yep, so it all depends on how it's prepped, how it's driven and stored, washed, etc. In my case, my goal has been to basically stop washing the car unless I really have to. Since changing my gameplan, I'm using the "duster" and QD/QW now, saving water, time, effort, and of course more work correcting swirls from the washing....But I use a car as transportation, and I am not obsessed about how much it shines. I also don't have a black car, which needs a lot more attention.
The only way NXT can last only 3 weeks would be if the car is washed almost daily and/or if the wrong kind of wash detergent was used (not using a detergent specifically designed for cars that does not remove the wax).Some people in the forums report NXT lasting as little as 3 weeks and Deep Crystal as long as 6 months, and of course, the reverse, and so on.
If you have a Genesis, it was made in Korea and can be waxed by the time you get it. How often do plan on waxing your car? If it will be once or twice a year, I would suggest a long-lasting synthetic car wax like Meguiar's Utlimate Meguiar's NXT Generation Tech Wax 2.0, or other equivalent wax from another brand.Thanks for your very detailed post. I just picked up my new 2013 Genesis last week and was wondering if it is a good idea to have a wax job now and if so what would be the best product to use?
What are any of you all using to wax your equus? Any suggestions?
