ABS module died
chrev
Raleigh, NC
Like some of my fellow Genesis owners the ABS module in my 2011 4.6 died. All of a sudden the pedal goes straight to the floor. There are no leaks at the calipers, master cylinder, or anywhere in the lines. What I am wondering is if all the various modules of Genesis sedans from 2009 to 2014 share the same ABS module. I found a clip with a guy saying he put a 2013 module in his car but he didn't say what motor the donar car had. I am assuming the 3.8L or Rspec will work but if anyone can confirm that would be awesome.
There's a good chance that if your car is smart-cruise enabled, that any smart-cruise 1st gen HECU will work. But there was a a design rev at some point. I'll leave the rest of the research to you.
2011 4.6 part ends in 5:
2011 Hyundai Genesis Parts - Hyundai Parts | Hyundai OEM Parts | Hyundai Factory Parts and Accessories
2014 5.0 part ends in 6:
2014 Hyundai Genesis Parts - Hyundai Parts | Hyundai OEM Parts | Hyundai Factory Parts and Accessories
Thanks for the reply. The part numbers are weird because the one in the car
Thanks for your reply. My part number ends in 3N300 which does not show up in any documentation or online part ordering. I am thinking this might be the old part number before they revised it.
Some older HECUs were recalled. Do you know for sure if your car was part of, or serviced for, the recall? Here's the recall on the HECU/brake fluid: 2011 HYUNDAI GENESIS 4 DR RWD which covers cars made up until March 28, 2012.
When the HECU failed in my 2009 4.6, it was before the recall and was replaced under the original factory 5/60 warranty. By the time the recall was announced the original HECU would have been recalled, but I already had the new design installed.
When the HECU failed in my 2012 4.6 last year, my car was not listed as part of the recall so it was not covered, but I have an extended HPP warranty (Platinum 10/120,000) that covered replacement at no charge.
Hyundai's 2013 response to NHTSA detailing their action plan for executing the recall: https://static.nhtsa.gov/odi/rcl/2013/RCDNN-13V489-9416.pdf
which states cars made before June 1, 2010 will all have HECU's replaced, after that they would replace brake fluid and inspect the HECU but would not automatically replace HECUs sight unseen. Their rationale is that at the time of the 2013 letter, the likelihood that the HECUs were damaged is dependent on "time in service with the corrosive brake fluid."
Call me cynical or conservative but my take on this is: Since Hyundai stated the longer you have corrosive brake fluid in the car, the higher the probability the original design HECU will fail. And since all brake fluid is hygroscopic, eventually all brake fluid becomes corrosive. So every single one of the original design HECU units in every 1st gen Genesis will eventually fail. Hyundai is a business and like all businesses they aim to maximize profits for their stakeholders. They were able to get NHTSA to agree to their limited recall, which did not comprehensively replace all HECUs in all cars with the newer corrosion resistant actuator valves. And even some of the newer designs that weren't part of the scope of recall still can fail (as with my 2012). So their fix isn't perfect either.
Bottom line: every single 1st gen Genesis sedan on the road that has an early design HECU is a rolling time bomb at risk of complete brake failure. Sooner or later, they will all fail. Protect yourselves, people.
Swapping in someone else's used unit or a Copart unit may be fine. But you will have no way to know if the unit is the newer design unless you can figure out by part number which units are pre-recall and which are post-recall. A smart service writer or parts counter clerk at a dealer can probably look it up for you.
Recommend you file a complaint on NHTSA. The more they know the more they can help protect our fellow Genesis owners.
Just got off the phone with the parts department. They think my part number ending in 3n300 was an older part number. The new part number is 3n3A0. He said he doesn't see where the part number was changed from 3n300 to 3n3a0 so he is pretty sure 3n3A0 is the newer part. I don't have any failure lights on my dash so I am going to try and swap the fluid before I drop the bucks on the new part.
I finally got around to changing it. For those that may run into the same problem here are my troubleshooting steps. First off when the valves fail you probably will not receive a code from the computer. However, the first sign aside from the brake pedal feel was the fact that cruise control wouldn't activate. I have a bi-directional scanner so I tested the acuator motors and they all tested fine. I figure that if the master cylinder was bad then it would more than likely be leaking so I temporarily ruled that out. Next I swapped out the fluid since I wasn't sure if that had been done by my dealership to the DOT-4 LV. After I swapped the fluid and bled the ABS and brakes the pedal went straight to the floor. I confirmed there was no air in the system. So I ordered a salvaged ABS module from ebay. All ABS units from 12-14 will work on this car. You just have to match the features. For example, if you have SCC and the module you buy doesn't then you will lose SCC. I wasn't sure if the ECU would be mad that I changed HECU computer so I swapped the computer from my old module to the new one and now she good to go. The manual says remove the junction block...not possible. So just remove the bottom of the junction block and rotate it out of the way. Its a squeeze but managable. Hopefully this will help anyone who runs into this issue.
I have the similar problem with my Genesis r-spec 5.0, the brake is still working but is not as sensitive as usual. The local repair shop would charge me more than $4000 to get it replaced. I searched online and found the ABS module 58020-3M3A6 from $1500 to $18000. Is it possible to have it replaced by myself? How hard is it? I would appreciate greatly if anyone can tell me how to remove the old one and install the new one. Thanks.
Hey chrev, I know this is an old thread so this is a long shot, but I was hoping you could clarify a few things in your post. I'm looking to replace the ABS module in my 2012 Genesis, and I found a salvaged ABS Module with the same features as my car. Two questions:
  • When you swapped the HECU computer from your old module to the new module, did you just remove the screws that attach the black plastic controller to the metal block and swap the controller?
  • You said to remove the bottom of the junction block, did you just remove the bolts attaching it to the frame without detaching the wiring so you could maneuver it to the side?
Thanks for posting your solution and thanks in advance if you can answer these questions!
Yeah for the most part a ton of the body components like the abs module are the same. On the 4.6 they have an option for an electric power steering pump… why that’s an option? No clue but certain things like that are optional but for the most part the layout is identical
I think the Diff is Elect Power steering or not. 3.8 motor has a belt driven Steering pump !
