landtuna
This problem has to have a simple solution but I have not been able to find it.
Parked the Genny 3 days ago and apparently the person last in the trunk did not close it firmly enough (although there was no indication it was open from dash lights). It drained the battery right down to the last volt. Everything was dead.
I hooked up my charger to the underhood connections and began charging but wanted to open the trunk to ensure no vapors would build up there. No way. Went through the manual - no help. Tried a variety of fob, master key and switches but it would not unlock. After charging finished this morning everything is back to normal.
So what did I not do (or do wrong?). I cannot imagine the Genny designers would not provide a fail safe way to access the trunk because, duh, that is where the battery is located.
Another related item: My charger will select 12V at either 2A, 4A or 6A rate. I have never had it fail to set correctly but when I charged the Genny it would only select the 2A rate. This means it took over 12 hours to completely charge the battery.
The manual says that a normal full recharge should be at a trickle rate for 10 hours and apparently there is circuitry that prevents any higher rate. Coupled with the fact I couldn't access the battery itself might have been a blessing as it surely would have generated explosive vapors inside the trunk otherwise.
