Thanks EdP. Was that always there or was that part of the update? I've been through the steering wheel settings a bunch and don't recall seeing that before. I'm going to go check it out right now!
Hmm. just looked in the manual and found this. It is on the arm rest buttons, not the settings.
Image did not copy.
Reverse parking aid function
(if equipped)
When you move the shift lever to the
R (Reverse) position, the side view
mirror(s) will rotate downwards to aid
with driving in reverse. The position
of the side view mirror switch (1)
determines whether or not the mirrors
will move:
Left/Right : When either the L (Left)
or R (Right) switch is
selected, both side view
mirrors will move.
Neutral : When neither switch is
selected, the side view mirrors
will not move.
The side view mirrors will automatically
revert to their original positions
if any of the following occur:
• The Engine Start/Stop button is
pressed to either the OFF position
or the ACC position.
• The shift lever is moved to any
position except R (Reverse).
• The remote control side view mirror
switch is not selected.
