ShoNuff
OK, gang. I've got an 09 V6/Tech which is acting up and the dealer has been unable to properly fix my problem.
Problem/symptoms: At cold start, engine idle is erratic jumping around between 500 RPM and 2500 RPM. At cruising speed, you can feel a shudder of sorts when you let up on the throttle (this is consistent). Sometimes, the car will start hesitating/shuddering even if throttle input is steady - this occurs at all speeds. The CEL is not lit and is apparently not showing any codes. The hesitation varies widely, sometimes being barely noticeable and at other times being rather acute (and unpleasant).
Car has been to dealership twice. The first time, the CEL was lit and threw codes P2195 and P2106 (both apparently relate to the oxygen sensor). Dealer "flashed the ECU." This temporarily lessened the severity of the problem but it didn't go away altogether. Problem gradually got worse over the course of two weeks, so car took a second trip to dealership. On second visit to shop, dealer applied TSB 10-FL-007 and asserts that it can't replicate the problem. Dealer is wrong; the problem persists.
I plan to bring the car to a different dealership next time, but am hoping some of you may have suggestions for what the service department should look for. A few possibilities occur to me:
1) Replace oxygen sensor; 2) check for vacuum leak; 3) check TCM (throttle control); 4) possible blockage in fuel line or filter; 5) malfunctioning fuel pump.
Any other suggestions?
