No sound when panic button is held
Kelly357
Genesis G80
Hello.
I just noticed that when I hold the panic button down on my key fob the lights will flash, but the horn doesn’t make a sound. Does anyone know how to fix this issue?
2015 G80
Hello.
2015 G80
Do the horns also not work when you press on the steering wheel? If so, the most likely solution will be to replace the two horns.
The horn works when I press the steering wheel, just not when I hold the panic button
I don't think you hold the panic button, just press it once. Genesis uses hold down functions for alternate operations like power doors or armored vehicle entry assist.
Thanks. It doesn’t sound when I just press it once either
The horn sound on the alarm is very weak anyway.
