MMADAWG
- Feb 22, 2024
- Genesis Model Year
- 2009
I dont claim to be a car guy or a mechanic but ive never seen anything like this if anyone is able to help with any of the symptoms id appreciate it, they are all or nothing when it comes to the symptoms of acting up
2009 HYUNDAI GENESIS 4.6L SEDAN TECHNOLOGY PACKAGE
INTERMITTENT STARTING ISSUES:
-Has no issue starting from the ignition switch button without fail but only in the mornings
-At lunch time 12pm EST sometimes the button will work, sometimes you have to put the keyfob in the key holder to start the vehicle
-Sometimes you have to open a door to get it to start
-Sometimes it will crank then shut off or feel like its going to shut off but starts
-Sometimes it will crank then shut off and continuously crank until cycled off, shows the symbol the the orange key light
-When the failure is occurring the seat will move forward and backwards, the steering wheel will move up and down
-OCCASIONALLY it will tell me to check the steering wheel lock
-When it is acting up by not starting the passive entry system will not work, keyfob will not unlock the doors with the buttons on the fob or on the handle
-When none of the above solutions work for getting it to start I have to hit the shift interlock into manual shift mode, run it in accessory mode, then switch it to neutral to get it to start (all while the keyfob is in the key holder)
-Other symptoms are the interior lights flash fast, the seat belt charm will beep fast until plugged in then its quiet, and the seat belt light will not go off even after being plugged in, passenger airbag light will flicker, radio will reboot
-(EVERYTHING WORKS WITHOUT FAIL IN THE MORNINGS NO LIGHTS, NO CHARMS, NO ISSUES AT ALL) STORED CODES: B1602 (PDC CAN ERROR) (POWER SEAT MODULE CAN ERROR)
(DRIVER DOOR MODULE CAN ERROR) (STEERING COLUMN MODULE CAN ERROR)
only other code is catalytic efficiency code, which was because i ran on bad O2 sensors for 6months when i had first got the car because I didnt have $1000 to repair them at the time
-CAR BATTERY TESTED GOOD, KEY FOB SIGNAL/BATTERY TESTED GOOD ALL THE TIMES IT HAS ACTED UP, it has been an ongoing issue since i got my car repaired 4 months ago for VC gaskets, purge valve & hoses, spark plugs, tube seals, gas cap, o2 sensors (all unrelated id assume but i didn't have these issues until after)
