PMCErnie
Ancient ‘steemed Member
- Jan 2, 2012
- Location
- Richmond, VA
- Genesis GV70
Poor Pat.
The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Genesis parts & accessories
Advertise with us!
Advertise with us!
The main electrical damage that I "assume" could occur would be to the battery I again "assume" that originates from any spark or discharge that may occur when you first connect the negative battery posts together; maybe a voltage spike as well. The only other components that could be damaged would be the voltage regulator/sensing devices that many modern charging systems have inline with the battery cables and alternator. Possibly other voltage sensitive devices in the car like control modules could be damaged as well. Just a guess on my part, because I never did a proper experiment to see what could actually happen on a newer car between the two jump methods.Oh geezLet's skip the details of my career and deal with the second question, which is pertinent to this thread.
You brought up the issue of where cables should be connected when jump starting a car, to avoid "electrical damage" - although you never explained what kind of damage would occur and why. I was simply pointing out that because automotive electronics need to be designed to survive what is known as "load dump", they are much more robust than people think, and not so sensitive that damage would occur if you connected the negative jumper cable to the battery versus the chassis - whatever difference you think that might cause.
Maybe I misunderstood you. Please explain exactly what electrical damage you were talking about, and why it would occur if the negative jumper cable went to the battery rather than the chassis.
LOL. I work in Radiology. I only have a basic rudimentary understating of electronics obtained through some courses taking over the years many moons ago.Do you understand that the negative terminal of the battery has a very low resistance, direct connection to the chassis? If so, why would you expect that the sudden connection of another battery to one or the other would be more or less likely to result in a voltage spike? What field of electrical engineering is your expertise in?
Finally someone who understands. Side note - do you think its best to jump at battery or connections under the hood? I am leaning towards the battery----? thx bThe reason you're supposed to connect the negative (ground) to the chassis, away from the battery, is to prevent the chance of sparks, when connecting it, from igniting any hydrogen gas emitted from the battery under charge.
Also, for cars with trunk mounted batteries, where they put a positive battery post under the hood, they use a chassis mounted post for the negative terminal, rather than having to run another heavy cable the length of the car back too the battery.
As a EE of forty years, I can think of no good reason, from an electrical standpoint, to use the chassis rather than the battery for the negative connection, considering the fact that they are connected by an extremely low ohmic connection (milliOhms).
Also, as someone who has designed electronics for car manufacturers, I can say that there's a lot of misinformation out there regarding how sensitive modern electronics are. Sure, there's a lot more electronics in modern cars and they are certainly more sensitive than light bulbs and motors, which is about all we had in older cars (other than the radio), but electronics designed for the automotive industry are required to work over a very wide voltage range and tolerate various over-voltage conditions for different lengths of time. They are much more robust than many would have you believe.
I think whichever is most convenient and allows for a good solid connection. However I guess there is some risk, when using the battery for both connections, that a spark could ignite methane gas produced while charging. Although I don't know how likely that is with today's batteries, especially those trunk mounted batteries which are vented outside. I suspect it's one of those long-shots that the lawyers make sure is included in the manual. (Like the instructions "don't drink" on the bottle of bleach - except for COVID of courseFinally someone who understands. Side note - do you think its best to jump at battery or connections under the hood? I am leaning towards the battery----? thx b
True, good point! I'm not used to those yet, even though I bought one last year, haha.
