11 4.6 4Door
Robsmith
2011 4.6 sedan, I Have new brakes an rotors front and back. Do I have to put it in service mode for the electronica brakes in the back or can I just change them without service mode.? I do not use emergency brake.Thanks
i have the second gen and i swapped them just fine without a service mode. BTW you should probably start using the E brake when you park. There's a pin in the tranny that keeps it from moving when its in park over time it can wear. Its a heavy car and using the brake can help it not wear so quickly. Its cheap insurance! The parking brake is free ripping apart your tranny for a stupid pin isnt.
Thanks
E-brake doesn't get much wear. It's normally only engaged when the car is not moving.
