11 genesis 4.6 code o2096
newguy12
Hello I just had a check engine light on my wife genesis. The code I am getting is p2096 lean fuel low. What should I try to fix first hose or pcv value
Do you know if the car has any unusual driving symptoms? Make it a point to inspect under the hood for leaks from the mass airflow sensor and the intake manifold and inspect all catalytic converters for cracks or leaks. How many miles on the car?
I drive it last night but I am not sure about unusual driving yet because my wife drives it mostly. It has 84k
I would check fuel filter, then fuel pump, then injectors/rail assembly. If it's burning lean and fuel delivery is the issue, I would suspect it to be the fuel system.
