Smash101
- Sep 12, 2023
- Genesis Model Year
- 2012
From mechanic:
It has a main fuse or relay that went out from plugging the fan into the cooling control module. Something grounded out when plugged in. Module wiring or module itself needs to be repaired or replaced for fan to work. The overheating is from fan not working.
I was able to get a reading on the fuses once I found a good ground for my meter. The hot wire from the relay to the fan computer wasn’t getting power, but it may only get it if the relay triggers. The thing is the fan had no power on it. The plug was disconnected. I researched some last night and it says the genesis can do a good job at cooling itself off just from driving and no fan activating. The control module probably fried before you got the car and they just unplugged it, replaced the fuse or relay that’s blown now preventing it from starting, and kept the car going instead of replacing the whole module. There’s no way that fan was running at all with no power. May just be a coincidence that you had no prior issues with overheating or ac not working as well.
