19 x 8.5 front
avalon
Toronto
Dear friends
are 19 x 8.5 front for G70 2020 OK? I had this configuration with 225 tires and hasn't noticed any problems - but now I'm choosing a new set and a salesperson recommended me 8 as 8.5 wouldn't fit or cause rubbing
Has anyone been driving 19 x 8.5?
Thank you
I have 18 x 8.5 with 255 at the front, they key will be to pay close attention to the offset. Mine is 35mm (Enkei Raijin ), I would guess that the same could work with 19" but it may be close. I have less than 1/4 inch clearance with my setup
thank you
actually I found the info that 19x8.5 (35 offset) is ok at front - and already installed..
thank you
I have the same size/offset rims for my G70, what size tires did you go with? I was considering 255/35R19 but worried about rubbing. Any issues? How's the handling?
Thanks!
Thanks!
no issues with 225/40 tire, I found the info somewhere that 255/35R19 is an acceptable tire size
