19x8.5 ET42
Kanar
Gents I need your help here,
I bought an aftermarket wheels for my 3.3t G70 and they are non-staggered wheels 19x8.5 ET42. What would be the required spacer specs I need for the front so it won't be rubbing the suspension/Fender?
Thanks
If you care most about handling, the proper wheel offset is as close as possible to factory 34mm. This maintains the as-designed scrub radius - especially for the front end.
Most commercially available spacers starts at 3mm, 5mm, the jumps to 10mm. So your best bet is 10mm for the front end, which will result in an offset of 42 - 10 = 32mm.
Thanks bud, this is what I have gone with. Cheers
