2 problems (Strange noise) in my car.
aliphp
Baghdad, Iraq
Hi all,
i've two problems with my Genesis 2009.
1st problem is :
there is a strange noise in my car often when the speed between 80 - 120 k/h.
the noise DISAPPEAR when i remove my leg from acceleration paddle.
what could be the cause ?
2nd problem is :
there is a strange click (TIK) in the transmission stik when i press the brake paddle.
is this normal ? or i should change something ?
I don't know where you live, but since you mention kph, I assume it is not in the USA, so not sure what your drivetrain warranty is. If the car is under warranty, you should probably take it to a dealer.
That being said, there was a TSB for 2009 vehicles (maybe some 2010) regarding some noise on the rear axle at certain speeds. The fix was to add a spacer to the axle. Obviously, you would need to discuss this with your dealer.
Thanks for your reply.
i remembered that i'd never checked the C Oil (Differential oil) for the axle.
and about the tik in transmission stik ?
That's the shift lock solenoid that keeps the shift lever locked in park until you have your foot on the brake. A small vibration in the the shift handle is normal. If it is making a loud noise then ask your dealer as something may have come loose.
Hi all,
1st problem is :
I had exactly the same noise in my 2009 3.8 and had mentioned it to the dealer a couple of times. They investigated, but I don't recall any actions. It only showed up at about 80,000 km and didn't appear to get any worse, so I lived with it until I changed the car at 120K.
Thank you for your reply .. it's small vibration :D
hmmm,
i'm gonna change differential oil and see what will happen.
The slight clicking noise you mentioned is something myself and others have and continue to experience. Seems to be a normal thing.
