20" Wheel Offset/Tire Combinations + Wheel Design Suggestions
thatjawncrazy
SUPPORTING MEMBER
16
4
Philly
Vortex951
880
93
I have 20x 10 rears on my g70. 40 mm offset and 285/30/20 tires. I am also lowered and rub over a few bumps in town. So a lower offset is going to make it slightly closer to wanting to run especially if you are lowered
thatjawncrazy
SUPPORTING MEMBER
16
4
Philly
thatjawncrazy
SUPPORTING MEMBER
16
4
Philly
Vortex951
880
93
Thanks. I figure 32 is the lowest offset companies really make? Haven't looked too hard yet but your info makes me think I could get away with 295, 20x10 rears, and 32mm offset. Do you have a pic?
32 will stick out farther than 40 would. Which in turn makes it more likely to rub. My stinger buddy had the same width as me and runs a 35 off set and he rubs just from accelerating hard. If you want to run a 295 I would look more for a 45 offset. Brings the wheel into the car slightly more and will give you more room to clear the wheel well
thatjawncrazy
SUPPORTING MEMBER
16
4
Philly
Vortex951
880
93
Ty again vortex. If I can only get 40 offset i'll stick with 285 and if i can get 45 somehow i'll go with 295. Are those ARK springs?
Yes they are the ark gt-s. I think gt-f sits a little taller in the rear.
CoconutRob
468
63
I did 20x8.5 front ET 32 and then 20x10 rear et 37. 235/35 front and 275/30 rear. My wheel has a big step lip so offset had to be custom to fit the car.
Lowered?
Cashby
136
33
Looks great. Also looks like I could go with another half inch in the front, and maybe a 245 on the front. Thanks, that helped!
I put a 3mm spacer on top of the 32 offset. still have room in the front.
Yep, Eiback lowering springs.
Looks good.
Thanks!
My muffler delete with resonators should be done today also :)
Cashby
136
33
19x10.5 you can do for sure with the correct offset.
To be honest, I am glad I did 20's cause 19's wouldn't fill the wheel well as much as I'd like. Depends on what suspension you did. My Eibachs lowered my car just under a full inch.
thatjawncrazy
SUPPORTING MEMBER
16
4
Philly
thatjawncrazy
SUPPORTING MEMBER
16
4
Philly
Vortex951
880
93
Yeah so i want more of a concave look. I figure I could do 9.5 instead of 10.5, and 32 offset instead of 45. This gives me more inner clearance but keeps the same fender clearance according to the offset calculator.
Kinda just writing this here for notes.
So as much as it will work I will warn you. If you are lowered you will rub your tires just from accelerating hard. My buddy has a stinger. Same width and a 30mm offset and his tires rub left and right. It looks super good tho hah
