Laxpro1376
- Mar 11, 2020
- Location
- Hilton Head, SC
My 2009 Genesis 4.6 is starts on all 8 cylinders but once the car warms up and RPMs dip below 1000 it misfires and stalls out. I can cold start it and then drive until I have to stop at a light where it goes down into idle RPMs. I suspect my fuel pump could be the issue. Another thing I have seen it could be is the Idle Air Control valve. I have disconnected the fuel line from the fuel rail and it pumps when the car is turned on (before starting). But I would assume that from how it starts up right away. Next I would like to have a fuel gage reading as it stalls to see if fuel pressure dips as it starts to misfire and stall. I borrowed a fuel gauge from autozone but it came with threaded brass fittings and the fuel line in the Genesis fits in with an o-ring and two set screws, not threaded fittings. Has anyone here ever checked fuel pressure on a genesis that could lead me in the right direction? Has anyone experienced similar symptoms?
