2009 fog lights just stopped working
hisert
Pennsylvania
My OEM fog lights went out at 89,000 miles. I replaced them with H8 LED's as recommended and they worked great for about 5 weeks then all of the sudden both stopped working at the same time. Since LED lights don't generally fail in all of my other cars I figure this might be something else causing the issue. Any ideas on where to look?
Both lights failing at the same time indicates a fuse. So check the appropriate fuse - see owners manual.
Definitely a fuse, but the lights can fail too. My replacement ones (only replaced to get the white look) originally failed, maybe due to wrong voltage, then I replaced them again and they've been fine.
I would be extra careful in replacing the fog lights and try and use the exact OEM bulbs. I recall several threads on this forum back in 2009-2010 when people replaced with different bulbs and the extra heat melted the cardboard (or whatever) shroud around the lights.
