2009 hyundai genesis 4.6L 4Dr sedan
2Bee1witu
hard starting after filling up gas tank, but after several or more turnovers the car will start
Welcome. This topic has been moved out of the community lounge and into the first generation Genesis Sedan forum...
There are several components in the fuel EVAP system that could be causing problem. There is a purge valve, canister close valve, canister air filter, and the canister itself. Could be any of those components that is causing your problem.
99% Hard start after fill up is a purge valve. Just did this myself for <$40. Easy DIY under the hood: pliers, trim tool and 10mm socket.
Purge Control Solenoid Valve (PCSV) Item Specification Coil Resistance (Ω) 14.0 ~ 18.0 [20°C(68°F)]
TL/DR DIY check: if you suck on it and it leaks, it;'s bad.
2012 part (I think the 09 is the same, but pls check for yourself):
