2010 4.6 Headlight wiring picture/diagram help
xplosive1
Can anyone help me with a picture of a driver side headlight/headlamp wiring diagram from the connector side inside the engine bay?
My car is being repaired and all 10 of the connector pins for the headlight have been taken out of the connector plug, and now it is up to me to put them back in place.
I need a picture like the one that is attached, except I need it for a 2010 V8, 4.6L driver side headlight. I couldn't find what I was looking for on the HMA website. My car has HID AFLS. Any help would be greatly appreciated. Thanks in advance for the help :)
Hi all,
Thought I would try this again. The car is almost fixed, and I still need to figure out where the pins go for the driver side headlight (the plug end was busted, so the wires are out, the new plug end is not color coated, so I need to figure this out on my own)
Please help if you can. Even if someone could take a picture of their headlight plug coming from the engine harness that would be great. I have looked over and over for the pinout diagram/schematic but still am not able to find one. I also contacted Hyunda Canada, Hyundai Motor America, and a few local dealerships but to no avail.
I cannot follow the colors from the passenger side as the wire colors do not match. Please help if possible, Thanks for looking
Hi all,
Hi I have the exact same situation going on did you ever manage to get a picture of the wiring that you could share?
After a few minutes of digging, the only pinout I could find related to the front end lights is the FAM (front area module) pinout. Unfortunately, it does not show wire colors, but if you can get access to the wiring side of its fuse block you might be able to ID the wires that way.
This is the 2012 manual:
I have no idea if this is feasible or not, but would it work to look at the back of the other headlight and do a mirror image of the wiring on that side?
