2010 GC 2.0 bad vibration
Moemantha
Its either the driveshaft or the diff. Makes the noise even with no tires and no cv axles attached. Starts at 80km goes away then comes back at 105km. Accelerating makes it go away, off throttle vibrates the worst. I tried getting driveshaft balanced but nobody here in Winnipeg has the right fixture to do it. One shop can make a fixture but that will take time and cost more. Anyone get their driveshaft looked at in their areas and found anything? Thanks
Turns out it was the driveshaft coupler. Looked ok untill I took it off and flexed it. Had cracking. Switched it with front coupler and vibration is gone. Checkem boys
I had the same issue, vibration and the rear coupler is cracked, hopefully it goes off when replacement occurs. thx for the info guys. also vibration goes away at higher rpm
