2010 genesis 4.6 transmission fluid recommendations
Koobieone
Found Amsoil signiture series ATF that says on back of bottle that it’s compatible with shell m-1375.4 fluid
Koobieone
USE the correct ZF brand transmission fluid. It is available online along with correct pan/filter.
Already ordered Amsoil...it says it’s compatible with shell m-1375.4 that genesis dealer uses for at 6hp26 German made transmission.....I had to go on my own no one would reply!!... not even feedback on zf lifeguard fluid on line that I’ve seen......
Koobieone
Seems like I’ve researched the hell out of this..... and no one else has.....tried to see if Amsoil would refund but there were absolutely sure there fluid was comparable....
Koobieone
Can I get some info...?????? How many liters do I need for a drain and refill on my 2010 Genesis 4.6 ???????
edizzle89
76
Columbus, IN
should be around 6 quarts, I bought 2 one gallon jugs (8 quarts) and it had a little left over.
I also went with Ravenol 6HP ATF which is made specifically for our ZF trans and was the cheapest. Did it right about a year ago and haven't had any issues.
Pedal Commander
