Mark_888
- Jan 9, 2009
I will plead no-contest, since I guess I had a hard time clearly understanding the following:I guess I am just used to buying sportier tires and not used to seeing those lower ratings, and if you would actually read what I wrote I said I was not aware of a lot of tires rated lower than V, I never said that they didn't carry them at all, so if anyone is exaggerating, its you exagerating about what I actually said. If the OP is solely concerned about price and not quality I am sure he can find some used tires.
"Unless you are buying garbage Chinese tires I don't know of many tires discount carries lower than V rating."
Not really sure if you are even talking about Discount Tire stores, or tires at any single Discount Tire store, or whatever.
There are probably not a lot of tires the size to fit a Genesis that are below H, but there are plenty of H tires available, and one does not have to be ashamed to buy an H instead of a used V rated tire. The Genesis Sedan Base Trim model comes with H rated tires as OEM (at least in 2009-2011).
Overall, I would guess that Discount Tire sells more tires at H rating and lower, than V or higher, but I can't prove that. For example, most Honda Accord and Toyota Camry models come with H rated tires (maybe except Accord EX and Camry XLE, but not even sure about those). I previously owned a Toyota Camry V6 XLE with H rated tires as OEM.
