2012 5.0 r.spec belt routing diagram
Jolson71
Anybody have or know where I can find a serpentine belt routing diagram for a 5.0 r spec??
Most belt makers have them on their web sites, like Dayco and Gates. Auto Zone does too.
Thanks for the reply. I did get it figured out, but still have a problem. Replaced the battery, replaced the alternator, and replaced the belt. The battery light is still on and intermittent "check vehicle power system" still flashes. Car starts right up, runs and sounds normal. What else could possibly be causing the charging issue? Is there a voltage regulator or power module in this system?
Check the cables where they go to ground in case of corrosion. Aside from that, I'd try getting a code. Most auto supply stores will lend you a reader.
