2013 (5.0 r-spec) It sounds like a small beep sound ....
videopho
Huey
DFW TX
Genesis GV70
emitting from the dashboard location and for the life of it I can't figure out where that small beep sound is exactly coming from and what for. It has been doing more and more frequent lately. It only happens when the engine is running and probably more frequent when the car is running which makes it even more difficult to detect. Otherwise the car seems to run normal.
Does any one have any idea?
got any video/audio?
videopho,
Is it happening when you drive strait, or when you are making a turn, or when engine is just running idle?
How long does that beep last?
I recall that I heard beep from dashboard area about 2-3 times when I was driving and making left turn. Beep lasted for may be 3-4 second while I was making a turn. Then it stopped.
videopho,
If I recall mostly when the car driving straight and the sound comes and goes very intermittently at best which makes troubleshooting is very difficult.
battery light on? Mine did the same thing recently when I noticed the battery light and had to replace the alternator.
It was the same ANNOYING sound when you have the car off but radio on...
Have you had your car serviced lately? I had new tires installed and they busted one of the TPMS sensors. They plugged in their scanner under the left side dash and forgot to remove it when they gave the car back to me. There was a beep every 30 seconds. until it was removed.
Brought her in for warranty service this past Friday
Dealer could not duplicate.
Go figure.
But car needs a new pair of rear bushings since one is making a small squeaky noise.
Another new issue just recently started popping up.
The left front sensors indicator intermittently shows up when there is even absolutely nothing near the front of the car.
Sensors go bad sometimes. I had one or two front sensors replaced under warranty several years ago. Now left front sensor is doing the same thing.
Try to clean those sensors first. If it doesn't help tell dealer and they should replace sensors under warranty.
