2013 headlight alignment
mp3weenie
I took my 2013 sedan with the performance package to my dealer and said that my low beams may be slightly too high as people would flash their lights at me going by so I asked them to check them. They actually said they aligned them and when I got it back, the beams were basically pointed down to the ground. I took it back and they said they aligned them again and was aligned to Genesis specs however they were still pointed too far down. I don't recall ever or rarely having to use my highbeams on a flat Road and now andusung high beams a lot. Shouldn't the low beams basically spread out completely horizontal from the car and therefore should not see an "abrupt ending" of the beams on the road in front of the car (it's like the beam is lighting the front of the car then stops with a straight line three car length in front of the car) ? . We're my beams to high to begin with or is this just wrong? I want them back the way they were!!! Thoughts?
You can check the aim of your headlights using the instructions here.
