Northern_Genesis
- Feb 3, 2012
Good day everyone
I have a 2013 Tech Package Sedan with 61000km on the clock. I winter store this vehicle and have since 2016 so it does not get driven except once the snow melts away.
When I picked this up in Jan 2015 I had an intermittent issue where the radio would lose all audio and the volume knob would do nothing regardless of the direction it was turned.
I had bought the car used from Hyundai and paid extra for the extended warranty. Fast forward to mid 2016 the radio just no longer works. I brought it to the dealership which replaced the entire system at a total invoice cost of $19000.
I was never happier to have bought a warranty.
Now in Sept 2023 after a 3 hour drive I parked it and lost all audio again. This time I located a blown 40amp fuse in the engine bay fuse panel.
I replaced the fuse and it instantly blew.
I did some research and bought a replacement amplifier off ebay.
I installed that amp this past December 2023, replaced the 40amp fuse and it worked flawlessly.
Now today, I started the car up no problem, it was parked for a month or so, and I idled it to circulate everything and to get warm.
I drove it about 3km, stopped at the post office, the radio was working perfectly. I got back into the car, turned it on and no audio again. I checked all the fuses, none are blown.
Does anyone know what is going on with this "Logic 7" amplifiers? How can they just suddenly grenade without warning?
I did not have the volume up past 7 and I turned the car on and heard the radio and then poof...dead.
I can access the ENG menu however I cannot reset the UTA (same issue when I needed to replace the prior amp). Again, they're are no blown fuses and I've done all the common fixes (disconnect the battery, remove the yellow fuse from the driver side interior etc.) all without solving this matter.
Does anyone know what goes wrong in this stupid Logic 7 amps and how to go about fixing them? I touched the amp in my car after driving, its warm but not hot and certainly not scalding hot like I would expect from a catastrophically failed unit.
If anyone knows what to do to fix this or knows of someone that fixes them I'd be more than thankful.
Cheers
Mike
Cheers
Mike
