2014 R Spec Exhaust
Kylocheff
This is clearly a knockoff of the magnaflow cat back made for the R spec. At 400$ is it possibly worth considering?
I put it on my 2013 sounds great lot lighter seems to run better, but I have the cat delete pipes also. I wish they centered in the rear outlet better.
So did you purchase and install this exhaust system and how do you like it ?
Yes I had it installed sounds good not that loud inside it is the loudest when first started then it gets quieter.
Did you go to this exhaust system directly from stock ?
Where did you get the secondary cat delete pipes ? Ark ? Are they a direct bolt on ?
Can't remember but they were not made for are cars probably for the coupe but read that they would fit. They fit great look nice and good welds work great. I can't believe how much the stock mufflers weigh one of stock pipe had a flat section that would reduce flow.
