5.0gang
- Sep 14, 2021
- Genesis Model Year
- 2015
My 2015 5.0 hit 60k miles, and according to my owners manual, you should change the ATF at 60,000 miles if under “severe conditions” (it is VERY hot year round where i live). My transmission shifted perfectly fine before, but I figured id change the fluid and filter as preventative maintenance because why not?
So i went to the dealer and got the pan/filter combo (stupid design Hyundai smh)
The owner’s manual didn’t state how many quarts of atf it takes for just a drop and fill, the parts guy said its about 4-5, so i got 6 quarts of the HYUNDAI genuine ATF SP-IV-RR just in case. (I double checked and this was the correct fluid the owners manual stated).
I lifted my car on level ground, dropped the pan, the fluid in there looked pretty good and had good color, didn’t smell burnt and no metal chunks etc. i put the new pan/filter in, filled it up until it started draining out, started the car and let it warm up 15-20 mins so the ATF could warm up a little and shifted through the gears several times etc then topped it off once more. It took a little less then 4 quarts. Once i was done i let it run a little make sure everything was all good, no leaks etc that was that.
Well, Now my car is shifting weird and is hesitating and jerking when shifting gears. Now I’m worried i somehow f**ked up my transmission and wish i would of just left it alone.
did i miss something? I asked my buddy who is a master tech at hyundai and he said i did it right so I’m not sure what the issue is. He even hooked up one of those fancy ass scan tools the dealers have and looked over all the transmission areas and said nothing looked wrong and there was no codes or faults etc.
Has this happened to anyone else?
edit: I forgot to note that this problem seems worse when the car isn’t fully warmed up
