2015 5.0 swap into a 2012 5.0 R spec?
Xgenesis
Spun a rod in my 2012 5.0 rspec. Having issues finding a replacement engine for my year. Will/would a 2015 5.0 swap in by chance even if it was a long block???
I beleive that the two engines may have different ECM modules and programming; so the 2015 engine may physically fit in the 2012 body, but may need an electrical modification/adaption to work. Just speculating.
That was one of the things I was worried about. I am hoping that all I would have to do was possibly use my front accessories and intake manifold and be good to go without any big modifications. Thank you for your reply.
Just swapped a 2016 equus motor and trans into a 2013 rspec. Mine spun a bearing as well. All the wiring plugs right exactly where it came from using the equus harness. Here are the issues I ran into so far. The engine would start run no issue. However esc light stays on. And shifter interlock will not disengage. Took it on a brief ride around the block. And there are definitely issues in communication modules/ecm. Will be swapping the entire harness later this week to see if I get a better result.
Did swapping out the harness help with the issue?
