2015 genesis sedan 5.0 TILT STEERING FIX
bigpapainscotia
BIGPAPA
NOVA SCOTIA , CANADA
Is there anyone who has a fix for my power tilt steering in my 2015 Genesis Sedan . It doesn't work with the easy access feature or the steering columns button . What should i do.. Maybe a fuse . Let me know.
Do you hear a hum or whine when you use the joystick control?
Start checking small. Fuses - > battery disconnect for a few hrs - > switch - > power at motor - > module
Yeah... it's usually something small. Start w/ the fuse(s). Had a Genesis tech say that they can become dislodged over time. Note that there may be more than one - for example, the A/C system has one inside & one under the hood. The owner's manual will give you the locations.
