2015 Genesis sedan passenger window
Riczek
I need help with a passenger window which intermittently does not respond to either the master switch or the door switch. It will not roll down sometimes until I open and shut the door heavily or sometimes just driving the car for a few miles both switches will operate the window.
Do I need new switches or is there something wrong with the regulator, the motor or both?
Any suggestions would be welcome and much appreciated.
It's only a guess but I'd be very suspicious of a harness connector being loose or corroded (or both) somewhere.
I have this very rarely on my drivers door, and I think that is because window stuck in the sealing like it is glued.
this always happen when car was not drived for several days
Thanks for the suggestion, I will take a close look at all the connections starting at the motor/regulator. Thanks!
You're welcome, G-81. I will be very interested in your results, because I suspect many of the problems we hear about are harness *connector* related (corroded, especially in cars older than five or so years). Of course I could be wrong.... We just need more information.
