2015 Genesis Sedan shift locked with LKAS warning light, engine light.
gksuelzle
My 2015 Genesis 30K sedan would not shift out of park, could be over ridden with shift lock button, but would lock up again.
This ocurred for the first time when starting up in afternoon. Towed to dealer was able to put into neutral after depressing shift unlock button under plastic removable tab. The dealer fixed this problem by replacing shift switch, but if happened again.
They then traced the my wiring from front to back and found pulled out rear wiring harness problem. Fixed that and now problem fixed. I have also noticed that my radio no longer switches from USB to radio source on its own. This is the only problem I have had other sirius radio would not activate at original purchase at 14k and replaced battery at 2 years of use.
I am thinking that some of these electrical problems are due to wire harness problems that can be fixed. My dealer did not charge for it because they said it was under warranty. I think I lucked out!!
Going through a similar issue with my 2015 that now has 80K miles on it. Dealer has not been of any help because car is out of warranty. I'll be posting something about my issues shortly, but thanks for posting this!!
You could try another Dealer because I am 2nd owner and my dealer in Ontario CA said it was on warranty.
