2016 3.8 HTRAC Engine Failure
With you buying the car with such low miles...was the car wrecked to begin with? I had two vehicles with ECU failures after welding work...seems these things are sensitive enough that when they weld, the surge of electricity is not grounding out well and can end up causing ECU problem. Neither of mine had drivability issues but posted odd codes that didn't make much sense.
In 1978, Honda replaced the engine in my Accord LX for $0 voluntarily!
