2016 Equus Ultimate
MG8
Proud owner of two Genesis vehicles
1,026
622
San Francisco/Las Vegas
no filter, you can either do a drain and fill x 5qts or do a complete flush x 10qts price depends on dealership but can range from 17.93 to 24.93 a qt
princelybug
266
85
SoCal
Equus (2011-2016)
Thank you, MG8.
Is 5qts the official capacity for a drain/fill? I see the Hyundai recommended fluid is GS ATF SP-IV-RR. Has anyone tried aftermarket fluid?
princelybug
266
85
SoCal
Equus (2011-2016)
DSXMachina
Just passing through.
149
117
43
Nashua NH
Equus (2011-2016)
Hi princelybug. I'm curious as to why you want to change the trans fluid. Do you have a very high mileage 2016 or have you been doing a lot of heavy towing? Hyundai doesn't recommend it and as a mechanic I can tell you it probably isn't necessary. If you are having a driveability problem (harsh or late shifts for instance) then it is very unlikely that a fluid change is going to make a difference. The fluid will never 'wear out' and if it has become contaminated then you have a much bigger problem than the fluid.
MG8
1,026
622
09 to 11 has the 6sp that fluid is life time
DSXMachina
149
117
43
Nashua NH
Equus (2011-2016)
Right MG8, but my response was to the OP's '16 8 speed (AT).
princelybug
266
85
SoCal
Equus (2011-2016)
DSXMachina
149
117
43
Nashua NH
Equus (2011-2016)
I'm the last person to advise against it! Me of the 2500 mile oil change intervals. Why? Because I want to. So if you want to change the ATF that's enough reason for me. :cool:
princelybug
266
85
SoCal
Equus (2011-2016)
Just updated to Map Version: 12.41.52
It took about 80 minutes from the time I first plugged in the flash drive.
I updated from Map Version: 07.43.43, which I presume is what came with the car from the factory (I'm the 2nd owner - my car's build date is 4/4/2015).
*Annoying fact - There isn't a prompt to unplug the flash drive after it completes the update. I didn't unplug it right away, so it started the update process all over again. I ended up going through the whole process twice! One would think programming in an "unplug" prompt would be simple and logical. :SMH: :annoyed: (n)
DSXMachina
149
117
43
Nashua NH
Equus (2011-2016)
Ha, I hear your pain, except I was in the loop from hell for 5 hours before I decided enough was enough and shut off the engine.
princelybug
266
85
SoCal
Equus (2011-2016)
Is there any way to get rid of or bypass these screens on startup?
EDC5B79D-012B-47AF-8723-8D39CC964D46.jpeg E04EB847-B422-485E-B40C-7CDF2DF07202.jpeg
princelybug
266
85
SoCal
Equus (2011-2016)
Just received my vehicle back from the dealership. Now, these 2 icons show up. Anyone know what they mean and how I can get rid of them?
1. What is the small "A" to the left?
2. Why are the folding mirrors showing up in red? (The mirrors do fold/unfold upon lock/unlock) IMG_7481.jpg IMG_7482.jpg
princelybug
266
85
SoCal
Equus (2011-2016)
Anyone?
princelybug
266
85
SoCal
Equus (2011-2016)
Just hit 60K on my Equus. Took her to my indy for trans pan/filter replacement. He was able to drain/fill just under 7qts of fluid. There is a noticeable improvement in shift quality. I recommend it.
If I still have the car at 120K, I'll do it again.
MG8
1,026
622
maintenance is the key .
DSXMachina
149
117
43
Nashua NH
Equus (2011-2016)
Hey -bug, save yourself some money. You did not need a filter. I guarantee that. The ONLY time a filter needs replacing is when something bad has happened to the transmission. Otherwise they NEVER get dirty or clog. They do not do the same kind of work as oil filters and air filters. Their only job is to keep chunks of stuff which fall loose from casting flash or gear teeth or clutches from getting up into the valve bodies and wreaking havoc.
If your tech charged you for 7 qts then he must have used a flushing machine to do the transfer. That's good because it gets most of what's in the pan, the pump and the torque converter. Dropping the pan will only remove a couple quarts at most. By using the flushing method there is no need to drop the pan. And therefore the filter would not have needed to be changed. Less work+fewer parts = less cost and less risk.
princelybug
266
85
SoCal
Equus (2011-2016)
Thank you for the advice! Will definitely heed for the future.
I wanted to replace the pan/filter this time since it might’ve contained metal shavings from being broken in since new.
