2016 Genesis does not lock via key fob
corneliusw
The unlocking feature works with the keyfob, if I hit the lock button on keyfob the light turns red but the door never locks. I also cannot use the outside drivers door to lock either, it will only perform unlock.
I have a Bidirectional Scan Tool and it shows 0 issues with vehicle. When I start the ignition, the door panel inside locks the car just fine when I push the lock button.
Anyone know what could possibly be wrong?
I would try replacing the key fob battery. Sometimes the simple solutions work.:)
Only 1 keyfob. I don't think it's a keyfob issue. The trunk also doesn't pop open with the buttons inside the vehicle.
Something that's related to the trunk + door is preventing them from working.
...The trunk also doesn't pop open with the buttons inside the vehicle...
Did you check the button in the ceiling of the glove box compartment?
Yes, glove department button is for trunk specifically, but I have pushed it in and depressed it, neither one makes an impact on anything.
