Kraig Wilkinson
SUPPORTING MEMBER
So much potential damage! Nothing would fit correctly on the reassembly process due to the thickness of adding saud insulation. Been there done that.I AGREE SO MUCH WORK AND POTENTIAL DAMAGE
That's a good idea. Easy 3nough to do in those spots. I had a 68 Bronco I owned and restored. I did that to every seface I could. Wow did it help out that tin can.Law of diminishing returns. And it's a VERY quiet car. I'll be getting dynamat installed in the doors and trunk lid when I replace the speakers. I'm sure it will be great without any further sound deadening/acoustic insulation.
Let me know how that speaker replacement t goes for you!Law of diminishing returns. And it's a VERY quiet car. I'll be getting dynamat installed in the doors and trunk lid when I replace the speakers. I'm sure it will be great without any further sound deadening/acoustic insulation.
I agree it’s a very quiet car as it is. Unsure how it would go back together with the added thickness.Let me know how that speaker replacement t goes for you!
Unfortunately, the installation date is mid-November. What I can share is that I got 2 sets of JBL GX608C component speakers (for front and rear doors) at 2.3 ohms. Only the fronts are components in the G80, but I wanted the 6.5" midranges to be identical and will be using baffles for enhanced sound. You can have two speakers with the same impedance (let's say 4 ohms) but DIFFERENT sensitivities/efficiencies (measured in db) and one set will be louder than the other under the same current/wattage. So I won't be using the tweeters in the rear door.Let me know how that speaker replacement t goes for you!
Curious which model G80 you have. Also, are you concerned with possibly losing any steering wheel controls, or voice integration?I am replacing the stock stereo
All my fault. I veered into stereo land, and made a misleading statement that I'm replacing the stock stereo. I have a 2018 base G80 without the fancy tech package (no pano sunroof or large infotainment screen or dial aft of the shift lever).Curious which model G80 you have. Also, are you concerned with possibly losing any steering wheel controls, or voice integration?
I've got the base G80 and the radio / stereo system stinks. Sorry, I know this is off topic, we could start a new thread.
I'll be powering a Polk Audio 8" DVC 750 sub with a Rockford Fosgate monoblock R2-500X1 amp and damping the rear deck. It will DEFINITELY sound better, but am using the stock amp for the door speakers, so the sub will be set around 1 or 1.5 out of 10 to keep from overpowering the remaining speakers.
Search "POOGE" for greater detail on audio enhancement. I'm a former Aerospace Engineer, so I know enough about speakers to be dangerous. Electrical Engineers are kings of that jungle. (And acoustic engineers of course...)
Thats is usually the way it happens. For me its when I get on this forum and start reading..... Next thing I know I am mounting up new tires or bolting 9n a set of mudguards..All my fault. I veered into stereo land, and made a misleading statement that I'm replacing the stock stereo. I have a 2018 base G80 without the fancy tech package (no pano sunroof or large infotainment screen or dial aft of the shift lever).
I'm not replacing the original amplifier or head unit which would bung up the voice control/steering wheel controls, just pulling the original speaker level input to the old sub and re-routing it to the monoblock amp to add some juice to the new (4 ohm) sub. The rest of the speakers are just "remove and replace," but will add a shitload of sound deadening material and baffles (to direct mid-woof into the cabin more effectively). The "new" system will be clearer and have a slightly greater volume due to the baffles and removing extraneous noise from the doors, floor and trunk as well as a tight, refined low end.
6 months ago, I never HEARD of a Genesis, and now I'm pimping my ride...This forum is excellent, but it can thin the wallet a little.Thats is usually the way it happens. For me its when I get on this forum and start reading..... Next thing I know I am mounting up new tires or bolting 9n a set of mudguards..
Yes it can! I heard of the Genesis before, but never really thought about buying one. I started off just wanting something newer. Then I started researching and I was hooked . Ended flying out to Chicago to get one and drove it 700miles home. 15 5.0 Ultimate. I just absolutely love this car. 420hp 28mpg!6 months ago, I never HEARD of a Genesis, and now I'm pimping my ride...This forum is excellent, but it can thin the wallet a little.
NICE ! ! ! ! Congrats on your purchase. You were smilin' for 700 miles.Yes it can! I heard of the Genesis before, but never really thought about buying one. I started off just wanting something newer. Then I started researching and I was hooked . Ended flying out to Chicago to get one and drove it 700miles home. 15 5.0 Ultimate. I just absolutely love this car. 420hp 28mpg!![]()
No problem at all, I think we have basically the same car, I'd love to get better sound out if it. But depending on how my 3 year lease goes, I may return my base '19 3.8 and find a '20 5.0 Ultimate. That should improve the radio system.All my fault. I veered into stereo land, and made a misleading statement that I'm replacing the stock stereo. I have a 2018 base G80 without the fancy tech package (no pano sunroof or large infotainment screen or dial aft of the shift lever).
I am sure you will love the 5.0 Ultimate TinsleyC.. The smooth acceleration of the 5.0 is Awesome. I can't imagine the car without a 5.0.No problem at all, I think we have basically the same car, I'd love to get better sound out if it. But depending on how my 3 year lease goes, I may return my base '19 3.8 and find a '20 5.0 Ultimate. That should improve the radio system.
If you're itching for a 5.0, you can transfer your lease. (I was considering a lease transfer for 6 months to a year as a "trial period" instead of buying it outright, but ended up pulling the trigger and slapped down a FAT down payment.) I'm not disappointed in the least. I drove the 5.0 and it was buttery smooth and offered power, but you have to be patient and wait for the higher RPM for the V8 to pull strongly. The 3.3T has less weight in the front end (positive for driving dynamics on the windy roads) and offers solid torque at a lower RPM. Definitely test drive the 3.3 and 5.0 back to back before you make the leap.No problem at all, I think we have basically the same car, I'd love to get better sound out if it. But depending on how my 3 year lease goes, I may return my base '19 3.8 and find a '20 5.0 Ultimate. That should improve the radio system.
I never did drive a 3.3 . However that seems to be the going concensus. I like the 5.0 for the Smooth acceleration. And out here in the middle of the country with 80mph speed limits the V8 thrives.If you're itching for a 5.0, you can transfer your lease. (I was considering a lease transfer for 6 months to a year as a "trial period" instead of buying it outright, but ended up pulling the trigger and slapped down a FAT down payment.) I'm not disappointed in the least. I drove the 5.0 and it was buttery smooth and offered power, but you have to be patient and wait for the higher RPM for the V8 to pull strongly. The 3.3T has less weight in the front end (positive for driving dynamics on the windy roads) and offers solid torque at a lower RPM. Definitely test drive the 3.3 and 5.0 back to back before you make the leap.
I owned a beautiful Audi A6 with sport package and 19” wheels. Loved it in every way except the dealer charges. Minor stuff and billed like it was major repairs. Oil cap and thermostat scared me after I was quoted by Audi. Before things deteriorated I decided to find a quality car under warranty. My Audi fear had probably grown out of all proportion after 2 Audi minor repair bills. Looked into the best mechanical automobiles and found Genesis . The G80 also had a factory warranty. Audi service was wonderful and professional so I expected the same. I was pleased with Genesis but would not say they have reached Audi’s level of finesse. The price was higher than quoted and the part came in wrong. Had to return for the higher priced part and another service visit. Work was performed well. Forgive the off topic diversion. I said to myself I’d never look at a Genesis but took a ride and drove a friend’s G80 and was hooked. Loved it enough to buy one for myself. One more diversion please. The dealerships are many steps behind Audi and BMW as far as personnel and site facilities. Just my opinion.Yes it can! I heard of the Genesis before, but never really thought about buying one. I started off just wanting something newer. Then I started researching and I was hooked . Ended flying out to Chicago to get one and drove it 700miles home. 15 5.0 Ultimate. I just absolutely love this car. 420hp 28mpg!![]()
Do you still like theses tires you have ?Don, agreed, the Michelin MXM4 245/45-18's all around on my G80 are quiet and grip & run well. Only have 4k miles on the car but unless something better comes along, I'll replace them with the same (but not from the dealership).
You really want that v8 lolNo problem at all, I think we have basically the same car, I'd love to get better sound out if it. But depending on how my 3 year lease goes, I may return my base '19 3.8 and find a '20 5.0 Ultimate. That should improve the radio system.
I have the 3.8 its okay , but having the 3.3 T would be perfect. But nonetheless the car is amazingI am sure you will love the 5.0 Ultimate TinsleyC.. The smooth acceleration of the 5.0 is Awesome. I can't imagine the car without a 5.0.
