- 43
- 19
- 8
- Genesis G80
I’m having the same problem with my 2020 G80. Back in Genesis again. Call has lessened thousand miles on it. Had the same issue with my 2017. I was told the problem was corrected or I never bought a 2020
Very Common problem.3.8 RWD, 30-80 MPH fastest I went. Vibration in seat and Wheel. Heavy at 70-80. What was done on drive shaft issues. Are the bulk of G80's Vibration free. Is mine a fluke or common problem?
Thanks TG
Filed a complaint about the vibration issue with Genesis USA on Monday the 17th and got a call today that they will begin the process of the repurchase. I’ve had more problems taking a pair of jeans back to Kohl’s. He said he get back to me next week with the additional information.Tomi, I have 2020 Genesis G80. Developed a vibration at 25027mph 2 weeks after purchase. My dealership has replicated the problem 3 times and determined it is in the torque converter, part of the transmission. Genesis does not yet have a fix. I registered a complaint with Genesis America customer care. They advise so far 20% of the vehicles have this problem and they are trying to figure out a fix to issues a TSB or recall. Meanwhile, they offered compensation or buy back. You should contact them and get a claim started.
You might want to read this thread. The 28-30 MPH vibration / flutter is apparently due to a driveshaft coupler.Had a 2017 G80 with no problems, leased a 2019 with a vibration problem. Genesis purchased vehicle back with 252 miles on vehicle. I leased a 2020 G80 after being assured the problem was solved but the same thing happened at 28-30 MPH car vibrates; dealer has tried to repair on several occasions After working with engineers regarding transmission angles and dealer problem still exist. Will be contacting Genesis for possible buy back. This vehicle has 2600 miles. Joe
Mines been at the Dealer for a month now. 900Had a 2017 G80 with no problems, leased a 2019 with a vibration problem. Genesis purchased vehicle back with 252 miles on vehicle. I leased a 2020 G80 after being assured the problem was solved but the same thing happened at 28-30 MPH car vibrates; dealer has tried to repair on several occasions After working with engineers regarding transmission angles and dealer problem still exist. Will bcontacting Genesis for possible buy back. This vehicle has 2600 miles. Joe
I finally got my 2020 G80 back from the dealer today after two months. They replace the driveshaft pursuant to a new TSB issue last week with a driveshaft it’s been in production since January. Much to my surprise after two months the vehicle is now worse than it was brand new. As of this date my vehicle still has less than 1000 miles on itI am going to attempt to have this elevated at Genesis Customer care but I also have a lemon law complaint started through the BBB. This is unacceptable behavior for anyHad a 2017 G80 with no problems, leased a 2019 with a vibration problem. Genesis purchased vehicle back with 252 miles on vehicle. I leased a 2020 G80 after being assured the problem was solved but the same thing happened at 28-30 MPH car vibrates; dealer has tried to repair on several occasions After working with engineers regarding transmission angles and dealer problem still exist. Will be contacting Genesis for possible buy back. This vehicle has 2600 miles. Joe
Check your states Lemon Law rules. In Ohio they 3 tries in the first year to fix it then you can take them to court (assuming you did not sign away your rights). On my G8 I got $5000 plus an extended warranty from GM for a drive train vibration they could not fix.I finally got my 2020 G80 back from the dealer today after two months. They replace the driveshaft pursuant to a new TSB issue last week with a driveshaft it’s been in production since January. Much to my surprise after two months the vehicle is now worse than it was brand new. As of this date my vehicle still has less than 1000 miles on itI am going to attempt to have this elevated at Genesis Customer care but I also have a lemon law complaint started through the BBB. This is unacceptable behavior for any
manufacture
Be aware that the BBB has nothing to do with Lemon Laws. Most folks don't understand that the BBB is a "For Profit" entity. They are not related to the the government in any way. They have nothing to do with enforcing any laws.Thank you. This is the second time it’s been back and well over 60 days total and downtime for the vehicle so if I don’t get any results from the BBB lemon laws will be next
Hello Tomi,Purchased a 2020 Genesis G80 and am suffering with a vibration issue, tires have been road forced balanced and replaced Michelin primacy MXM4 245/45R18. Any suggestions? Anyone have this issue resolved? What works? Thank you Tomi
I have to ask, to me, once a lug nut is snugged up, even finger tight, there is no play between the wheel and hub. So let's say they're tight between 15 and 30 ft.lbs each - and there's no possible movement going on, how could torquing then to a higher number have any affect on anything regarding wheel movement?I have retourqued my lug nuts to 78 ft/lb and inflated the tires to the correct psi and the car is vibration free for the most part. Torquing the wheels to the proper spec had an immediate effect on this car. I hope this helps.
Uneven Torque/load distribution across 5 nuts is the issue. The wheel is not moving like you said but its not tightened evenly.I have to ask, to me, once a lug nut is snugged up, even finger tight, there is no play between the wheel and hub. So let's say they're tight between 15 and 30 ft.lbs each - and there's no possible movement going on, how could torquing then to a higher number have any affect on anything regarding wheel movement?
Maybe I'm missing something, or maybe there is movement or flex between a wheel and hub even under torque - please educate me.
You can also take a look at the owner's manual it says something about vibration and lug nuts torqueUneven Torque/load distribution across 5 nuts is the issue. The wheel is not moving like you said but its not tightened evenly
