20x10/20x11 staggered
Jalexe
Huber Heights, OH
I was wondering in the name of "pushing the envelope" of wheel sizes and offsets, could you run 20x10/20x11 staggered setup? I have seen a 20x10 all around set up (here is the pic from avant garde wheel website) so i know that 20x10 in ther front would work, just really wondering how 11's in the rear would fit,or if they could.
  • Like
Reactions: MG8
20+ views and no comments. I would have figured i would had at less one skeptic....
I tried commenting, but got an error. I will expand on this when I get back to my desk.
All depends on offset of course. User GarciaFactoryUS was running 20 x 10.5 +45 with 20 mil spacers, effectively a 65 offset. 11's with a slighter higher offset say 5 more should fit if there is enough clearance between the inside of rim and car body. Fenders were pulled, factory camber maxed out, running air suspension and had minimal clearance to fit the rim mentioned above.
looking to hear your comment, hey any pics of the type II lip installed on your car?
I figured that would be the case, I have seen so many 10.5 rear setups, would assume that running an 11 would fit also. Also with 245/35 (f) and 255/35 (r) would give it a nice modest streched look.
I thought the offset would be +25 with the 20mm spacer in stead of 65. I remember reading that stock wheel offset is approx +31...correct me if im wrong.....
Essentially, depending on how aggressive your offset and disk, 11's are doable. It boils down to camber, pull, ride height and tire stretch...which you already know.
How much work are you willing to do to make them fit? Anything beyond +20 would be rough with stock fenders i would think. I am running +21 on 10.5 and there is a 1/4" poke at least, but my camber is fairly tame. Tires are 245/40, so a little stretched.
picture.php
picture.php
With your rear wheel measurements in mind,i got a chance to check out willitfit.com, I figure that between +28 to +23 (+23 is pushing it) would work. Of course there more that likely be some poke and camber. If depending on offset, pulling fenders. Also to take into account ride height...
Either way, it looks like you will either need spacers or to go custom setup..
oh yeah, for some reason the willitfit.com link turns to a porn site.....i have no idea it would do that...WARNING!!!!
10.5 is as wide as you can go if you want it to sit flush/tuck depending on ride height. Anything wider will poke unless you pull and/or roll your fenders.
